Advanced Alternator/Battery Question...
My buddies and I have an argument going about alternators and batteries. The basic question I have been required to ask is..." If you have a car with an alternator and no battery and, another car with both and alternator and a battery and, you also have a totally controlled "so-called perfect world" where no other possible mechanical or technical problem can arise except in the alternator. If both were started and then set free driving as usual with normal wear and tear in this perfect world to see what alternator failed first, which one will fail first?
Will the car with just an alternator last longer or will the car with both alternator and battery last longer in our perfect world?
Can you please explain your answers aswell.
Also if any answers have to due with the resistance of the battery in the field can you explain that aswell.
Also... Does a alternator vary its output of power due to the battery being some sort of resistance in the field?
Also ... If the battery is removed from the vehicle when running will it cause the alternator to surge and create full power, and will this wear your alternator and potentially damage electrical componenets?
Also...Do alternators work differently in modern times as they did 25-30 years ago?( I dont mean single vs triple coil either) I mean the basic all around function?
Also... Can an alternator work at different levels of internal stress that will LEAD TO PREMATURE FAILURE? Will an alternator that produces more power wear quiker that one that produces less?
Thanks alot to all that help/ you are settling a HUGE argument!!!!
Alternator require the battery load.
Without the battery load, there is nothing to "ballast" its output and most likely, the car will not run as the electronics cannot take the chopped power that the alternator delivers.
So totally moot.
Irrelevant. Cannot be used without a battery.
Alternator output is regulated by switching its field windings on and off in response to voltage.
Alternator hasn't changed materially since it was invented --- except for the use of solid state diodes to rectify it into DC
Yup. Most alternators are designed to be run at about 25% of rated or so continuously.
Use it at rated capacity, and it fries very quickly.
Why don't you just study some basic theory here:
Alternator - Wikipedia, the free encyclopedia
As far as theory goes... I UNDERSTAND FULLY!!!! I am trying to settle a 1000$ dollar bet if you must know between two of the guys in the shop. They agreed to settle it by posting in a forum where WE THOUGHT we could find intelligent answers. Except I find some wize azz big mouths quipping about the battery needed to start the vehicle and another joker telling me to learn theory!!! WTF? i UNDERSTAND THE DIFFERENCE BETWEEN A HAND CRANK AND GENERATOR AND STARTER/BATTERY/ALTERNATOR! I ALSO UNDERSTAND THE BATTERY ONCE REACHING FULL CHARGE ACTS AS RESISTANCE IN THE FIELD CONTROLLING THE AMOUNT OF AMP OUTPUT DISTRIBUTED BY THE ALTERNATOR THUS GREATER LOADS WEARS ALTERNATOR FASTER!!!!!!
IT AINT ABOUT ME THO!!!!!! WE ARE TRYING TO SETTLE A BET WITH MULTIPLE INTELLIGENT RESPONSES.
THANKYOU!!!
I don't know what this means, but the battery and the alternator are two separate entities. The alternator looks at the voltage in the system, and determines what it needs to do from that. The battery is also hooked to the system through the same set of wires, but it's just storage for the next time the car needs to be cranked over. And it does add a little bit of stability to the system, since if the voltage does drop below 12v for some reason, it will start to contribute. It's also a good noise sink for any high frequency noise that may be riding on the 12v system.
Also... Does a alternator vary its output of power due to the battery being some sort of resistance in the field? No. Like I said before, the alternator just looks at the voltage level in the system(in reality the regulator does this, and controls the alternator, if you want to get picky about it).
It could cause a small surge, because the alternator needs to react to the change in load when you take the battery off. If the battery was really down on charge, and the alternator was working hard to charge it, it could take a split second for it to react and trim back. Now if the regulator was faulty and the alternator is running wide open, the battery will be the only thing trying to hold the system down to a reasonable voltage, and will be boiling in the process. In this case if the battery is disconnected, yes components will be ruined because the faulty alternator will send the voltage sky high.
I have got to go to supper...I'll be back.
They work the same as the always did, a field winding rotating inside a stationary winding which generates 3 phase alternating current. There have been improvements in the electronic parts of the alternator, and some different physical configurations of each component, but they all still work the same.
I would say yes, an alternator with more load would be more prone to failure and have a shorter life. I say this because;
1. More load creates heat. More power generated in the windings heats the windings, and we all know heat over a period of time will shorten the life of various materials like insulation, and the electronics will be going through more heat cycles, such as the diodes.
2. More load makes the alternator harder to turn. This creates more load on the bearings of the alternator as the belt is trying to turn it. I think we all have had a squealing alternator belt at one time, and know how tight the belt has to be to keep it from squealing right after cranking the engine.
I believe abusing a alternator could lead to premature failure, but obviously the alternator is designed to do a job for a reasonable amount of time before it fails. They all will fail eventually, but I believe the a "babied" alternator would have a longer life.
Ok.. side point... what I ment by the Battery being a resistor in the field is this.... The battery, when not at full charge, does not provide the resistance to resist the alternator, ( it is not a draw but a passive resistor till fully charged) therefore, the alt charges the bat until full charge then, the amount of resistance is reached in the bat and the alt cant push through the resistance and the alt backs off amp out put due to the regulator sensing this. Thats how I understand it at least. And... if the battery was removed from the field the reg on the alt senses no resistance and cranks the amps out as if the bat was full dead. And the alt has no real mech parts that will fail due to added electrical load... it will be a diode or reg failure or the coil will burn...possibly the fan...
Like i said tho... If these idiots would let me settle it , it would be done. But ,we needed to do this...
I appreciate your time Franklin!!! I hope others with the expertise will jump in... Thanks in advance guys!!!!
Franklin, when you have the vehicle running and you remove the battery from the field why would there only be a short spike in power? whats the difference from the battery removed from the field and a totally dead battery? Does the regulator or PCM decipher the load and resistance variation that would be present with a battery either in or out of the field?
Remember... THIS IS ALL FRIENDLY!!!
The way the questions are framed indicate a need for the OP to take a few introductory course in basic electricity / electronics theory.
A selection of them is found here:
http://www.techlearner.com/AZTopTutorials.htm
In the real world, the alternator sees the battery as a load, just like it would see the heater fan or any other draw in the vehicle as a load. The alternator is it's own part of the system, and the only thing it looks at is the voltage level of the system, so the only way it can "see" a load is by the voltage drop the load creates. If the battery is down, it pulls the voltage level of the wiring down, and the alternator reacts to this, nothing else. It doesn't see "resistance" it looks at the voltage of the system.
So if you still want to think of the battery as a resistor, then the resistor when placed in the system, would create a load and drop the voltage, and the alternator would react to this. If you disconnected the battery, you would be pulling the resistance out of the system, which would be pulling the load out, and the voltage of the system would rise, and the alternator would "relax" and trim back it's output.
Internal resistance - Wikipedia, the free encyclopedia
With the move from analog to digital, new demands are placed on the battery. Unlike analog portable devices that draw a steady current, the digital equipment loads the battery with short, heavy current spikes.
One of the urgent requirements of a battery for digital applications is low internal resistance. Measured in milliohms, the internal resistance is the gatekeeper that, to a large extent, determines the runtime. The lower the resistance, the less restriction the battery encounters in delivering the needed power spikes. A high mW reading can trigger an early 'low battery' indication on a seemingly good battery because the available energy cannot be delivered in the required manner and remains in the battery
Figure 1 demonstrates the voltage signature and corresponding runtime of a battery with low, medium and high internal resistance when connected to a digital load. Similar to a soft ball that easily deforms when squeezed, the voltage of a battery with high internal resistance modulates the supply voltage and leaves dips, reflecting the load pulses. These pulses push the voltage towards the end-of-discharge line, resulting in a premature cut-off. As seen in the chart, the internal resistance governs much of the runtime.
Figure 1: Discharge curve on a pulsed load with diverse internal resistance. This chart demonstrates the runtime of 3 batteries with same capacities but different internal resistance levels.
Internal battery resistance
NO, The battery is not in the field circuit. A small percentage of the ALT power output goes back into the field circuit
NO, the voltage regulator controls the amp output of the ALT, removing the battery can only cause the ALTs amp output to go down.
I have seen more ALT using DELTA windings vs a Y configuration in the stator, delta will produce higher current output. The stator is still just a 3 phase AC output. There have been improvements in the field and voltage regulator circuits.
YES, higher outputs causes higher internal heat. Heat is the biggest enemy of all solid state electrical circuit. Poor heat dissipation is a close second. The G2 ALT bridge rectifier is the best example of poor heat dissipation I can think of, this ALT should only be used at 50% of it rating for constant output, loads (edit.. "over") **** 50% should be of short durations.
So my answers are the same as Franklin2…. Is case you needed further input.
But I do have a question… how can guys working in an automotive shop be able to afford a $1000 bet. Maybe you should charge the customers less.
50% is actually pushing it with the loads people are running --- tuners, towing, no cooldown, heat...
You mean loads of over 50% should only be for short durations.
They can afford $1,000 bets, afford to be foul mouthed in making demands on forum members because of what they pay us to answer the questions.
