DRVIESHAFT HELP!
Old Feb 17, 2012 | 04:12 PM
Tim J Miller's Avatar
Tim J Miller
Exclamation DRVIESHAFT HELP!
i got a 78 ford f250 long bed single cab. 4wd dana 60 rear and 44 front (i believe) 4 speed manual 351m with a married t case. I broke a rear driveshaft dead center... dont really know how to go about fixing it. I have cut both the old ends of the driveshaft and was thinking about just welding them into another pipe. But thats a last resort. would like to buy a used one or new. or something. Any advice is much appriciated.
Old Feb 19, 2012 | 12:25 AM
mudder460's Avatar
mudder460
I would see about finding a local shop that builds driveshafts. You don't want to just weld the ends to some pipe, it has to be balanced otherwise you are going to have bad vibrations. Your only other choice is to find another similar truck and get the driveshaft.
Old Feb 19, 2012 | 07:27 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
D7TZ-4602-AE .. Driveshaft / Obsolete
Applications: 1977/78 F250 4WD Regular Cab 8' bed (133" wheelbase) / 300 I-6, 351M/400 / Dana 60 rear axle / New Process 435 or Warner T-18 4 speed M/T.
GREEN SALES CO. in Cincinnati OH has 1 = 800-543-4959.
Old Feb 19, 2012 | 07:45 AM
CalebJns's Avatar
CalebJns
I had to get a new one for my '78 F100 SWB...cost me around $300. Took the guy less than an hour and I was out the door. You'll need both the sleeve (front) and the rear yoke, as well as precise measurements from the tail shaft to the center of the rear yoke...if you have the old on, it wouldn't hurt to take it with you to the shop...
The other option (as mentioned above) is to try to find another truck with a good drive shaft...I searched junk yards for a week plus, and found plenty, but majority of them were bent from where the trucks were picked up with the fork lift for placement in the yards...
Old Feb 19, 2012 | 12:02 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Junk yard and 2 new u joints or drive line/shaft speciality place, its not something as simple as it seems to build.
JY and maybe 25 bucks and away you go, now you can tap or press in the new u-joints.
burnthelight88
Jan 30, 2018 11:40 AM
Tim J Miller
Feb 17, 2012 08:36 PM
blacklabel21
Aug 16, 2010 07:25 PM
hairyboxnoogle
Mar 6, 2010 01:28 PM
tecgod13
Nov 17, 2009 07:47 PM
