IPR O-Ring Question
Old Feb 17, 2012 | 11:50 AM
gmcbride's Avatar
gmcbride
IPR O-Ring Question
I had my IPR out and found the first o-ring on the end was split so I replaced it with a hydrogenated nitrile butadiene rubber (HNBR) o-ring I had in the garage. These are supposed to have a high tensile strength and withstand high temps. Can anyone tell me how much trouble I may have caused myself? Thanks very much, George.
Old Feb 17, 2012 | 05:32 PM
BLADE35's Avatar
BLADE35
Man everytime I need an oring I can never find the exact size I have to make a run to FORD
Was the oring you used oil resistant?? and exact size and same thickness??
Does the truck not run now???
Can you watch ICP & IPR% to see if its bleeding by your oring
Old Feb 17, 2012 | 06:10 PM
gmcbride's Avatar
gmcbride
Benny, thanks for the response. It fit and everything seems okay. I'm just don't want a future problem. I got them from Harbor Freight and while the box makes no mention of oil it does say "more resistant to chemicals than most orings?
dieseldogtom
Jan 27, 2018 06:41 PM
El Campo
Jun 23, 2016 07:11 PM
rat49f6
Feb 13, 2013 05:24 PM
fordpride
Nov 12, 2011 09:38 PM
