HPOP fitting oring
Old Nov 12, 2011 | 08:08 PM
fordpride's Avatar
fordpride
HPOP fitting oring
Is the orings on the HPOP fittings a specal kind of oring are can I pick one up at NAPA if does anyone know what size ?
Old Nov 12, 2011 | 08:20 PM
F350-6's Avatar
F350-6
They need to be Viton 90. I think the size is -906.
Old Nov 12, 2011 | 08:32 PM
fordpride's Avatar
fordpride
Can they be had at a parts store ?
Old Nov 12, 2011 | 08:39 PM
F350-6's Avatar
F350-6
Sometimes. The other option is to search for an o-ring dealer near you, but they will likely be a M-F type place.
If you're in a pinch, a regular Buna N o-ring will work for a while. Using loctite 680 on the threads will also help if you make sure the threads get spotless clean and let it sit for at least a few hours before start up.
Old Nov 12, 2011 | 08:41 PM
DRRXR's Avatar
DRRXR
parts
1994-2003 Ford 7.3L Powerstroke - Alliant Power High Pressure Pump Seal Replacement Kit. AP0011
Old Nov 12, 2011 | 08:44 PM
fordpride's Avatar
fordpride
how about these
NAPA AUTO PARTS
Old Nov 12, 2011 | 09:01 PM
F350-6's Avatar
F350-6
Originally Posted by fordpride
how about these
NAPA AUTO PARTS
If they're in stock and the kit contains the right size, then I'd say yes, they will probably work. They don't list the Viton rating, but they should do just fine.
Kind of pricey though. If they are -906 o-rings, then you can get them much cheaper. O-Ring, Viton, AS568A-906, Round, PK25 - O-Rings - Supplies - 1WHN4 : Grainger Industrial Supply
Of course, if you need it now, then around $8 on a Sunday is hardly worth complaining about. Might be wise to pick up an o-ring kit from Guzzle though so you're ready for next time something pops up.
Old Nov 12, 2011 | 09:06 PM
fordpride's Avatar
fordpride
is that the ones i need i have a grainger by my house i could hit on monday
Old Nov 12, 2011 | 09:24 PM
F350-6's Avatar
F350-6
Those are the super duty HPOP o-rings. I'm not certain it's the same for the OBS. Bob would know, but I don't know if he would, or should share.
Others will probably know also. Just for reference, here's Alan's o-ring chart from the SD 7.3 Powerstroke O-Ring Chart
Old Nov 12, 2011 | 09:30 PM
fordpride's Avatar
fordpride
This is what i found does this sound right ?
For the -6 fitting (the ones on the HPOP) the o-ring is a "-906" (.468" id x .078" wd).
Old Nov 12, 2011 | 09:33 PM
F350-6's Avatar
F350-6
-906 (dash 906) is what I linked above at grainger, so it would make sense they are the same as on the SD fittings.
Old Nov 12, 2011 | 09:38 PM
fordpride's Avatar
fordpride
holy crap wally world has loctite 680
Thanks Chris im gonna hit grainger monday
dieseldogtom
Jan 27, 2018 06:41 PM
El Campo
Jun 23, 2016 07:11 PM
kudunk06
Oct 27, 2011 11:05 AM
dryfly
Oct 1, 2007 07:44 PM
