smog pump delete bracket
Old Feb 17, 2012 | 11:10 AM
revans9295's Avatar
revans9295
everybody talks about using it on there 5.8 . but i cant find one. i have a 1990 f-250 4x4 with a 5.8 . i want a delete bracket for the smog pump. i found one for the 5.0 would the 5.0 work on the 5.8 ?
Old Feb 17, 2012 | 11:13 AM
f100beatertruck's Avatar
f100beatertruck
I was looking at the front of my 5.8 in my 90 bronco yesterday and it looks like if you simply remove the pump and use a shorter belt that's all you'd need to do.
Old Feb 17, 2012 | 11:16 AM
revans9295's Avatar
revans9295
do you have any idea on the shorter belt length ?
Old Feb 17, 2012 | 11:18 AM
f100beatertruck
Ok, did some reading. Some years allegedly have different belt routing and the exact belt length you need is unavailable. Others have reported issues with belt flap and jumping off due to the longer span between pullies without the pump.
This, Proform Smog Pump Eliminator Bracket (68110) appears to be the solution. You may need a shorter belt.
Also it seems that if you have a tensioner on top between the alternator and A/C you're fine to just delete the pump and run a shorter belt. If you have the tensioner on the side between the alternator and smog pump you need the eliminator.
Old Feb 17, 2012 | 11:21 AM
76250_4x4's Avatar
76250_4x4
ive done a couple of these. just get a belt that is 2.5 inches shorter than stock
Old Feb 17, 2012 | 12:52 PM
White Max's Avatar
White Max
If you use an alternate belt routing, you can do without an eliminator with the side mount tensioner.
See posts #5 and #7 here:https://www.ford-trucks.com/forums/1...-question.html
Old Feb 17, 2012 | 01:46 PM
revans9295's Avatar
revans9295
the proform eliminator bracket 68110 says it is for a 5.0 will it work on the 5.8 ?
cod105ey
17
Jan 7, 2023 05:45 PM
myakkacracka
Mar 23, 2015 10:56 AM
ricky1
Mar 12, 2013 06:51 AM
FordYoungGun35
Jan 9, 2013 10:56 AM
DPDISXR4Ti
May 25, 2012 08:56 PM
