Smog pump delete
Old Sep 3, 2012 | 06:39 PM
FordYoungGun35's Avatar
FordYoungGun35
Smog pump delete
Got the smog pump off and someone posted a diagram saying I needed an 84.5in belt but it shows the tensioner above the alternator which is false he tensioner is below it... So does anyone know what size belt I need for a smog pump delete? 96 5.0
Old Sep 3, 2012 | 07:17 PM
Midnite1987's Avatar
Midnite1987
On my 95 315 I bypassed the top idler all together. But my belt will be different length being a 351
Old Sep 3, 2012 | 08:37 PM
marknford's Avatar
marknford
Smog pump delete
I by passed my smog pump years back. All you need to do is get a piece of wire close to same thickness as a belt and run it around all other pulleys like you would your belt and mark the new length. Take that piece of wire to parts store and have them match a belt to that length.
Old Sep 3, 2012 | 09:24 PM
FordYoungGun35
Came out to 91 1/4.. Everyone who needs to know right that down it will save y'all a lot of trips to autozone
Old Jan 8, 2013 | 04:57 PM
strokinout's Avatar
strokinout
I know this is a bit of an old thread, but figured I would post my situation here instead of starting a new thread. I have a '96 with a 351 and my smog pump seized on me. I just used a belt off an an '89 (I believe) f-250 with a 351. It changed my routing slightly but works great.
Old Jan 9, 2013 | 10:56 AM
Freightrain's Avatar
Freightrain
With a good posting "title", it should be easy to search next time. I did that with my '89 this past fall.
myakkacracka
Mar 23, 2015 10:56 AM
baddad457
Jun 2, 2012 01:56 PM
revans9295
Feb 17, 2012 01:46 PM
BearFootCustom
16
Jun 3, 2010 10:52 PM
rsmack
Aug 24, 2004 03:23 PM
