Distributor Oil
Old Feb 16, 2012 | 08:11 PM
Ole 64's Avatar
Ole 64
Distributor Oil
Hey guys - got the ole 64 to idle, ck & set timing - it was off . Loosened dist. hold down bolt and distributor wouldn't move. Finally tapped it with pliers and it advanced several degrees. I tapped it back to about 5,6 or 7*,,,, I hit it back, but it would not go to 4*. Hard to read marks, so I used soap stone and wiped it gently to see the timing marks. Also, it was poping bad when revved up, so I reset carb/choke settings -helped very little. I'm going to rebuild carb next.
How many oil drops & how often should I add to the distributor shaft? Will straight 30 be ok or 10w30?
What is the best way to get the distributor to free up?
All input and help is greatly appreciated!!
Old Feb 16, 2012 | 11:35 PM
huckdeuceman's Avatar
huckdeuceman
Well? it sounds like your dist is almost froze up? when was the last time the engine was
cranked up? you could put a little (PB Blaster) in /on the shaft but you should not have too? I would loosen the bolt on the dist, then spray some blaster on the shaft, then mark
where it is before moveing it, then try and work it back and forth till it moves freely!
put it back where you marked it and start it up, then set the timing!..plus, remember the
dist shaft is what runs the oil pump, so you might have a prob with that?..hope this helps?
Old Feb 17, 2012 | 08:08 AM
robertr2D's Avatar
robertr2D
Tight Distributor
If your engine turns over the shaft isn't your problem. Its the housing thats not wanting to move. First make sure you don't have a 2 bolt hold down. My 62 has 2 hold down bolts, one on each side. Then thread loosener should do the trick. If all else fails a little heat right wear the housing goes into the block. Stay patient. As far as oil 30w or 10/30 is fine. I add a couple of drops everytime I change the oil.
Old Feb 22, 2012 | 10:09 AM
phjbbu's Avatar
phjbbu
I would agree w/Robert, but I would suggest sticking with SAE30 viscosity since that ol' shaft is in there warm and spinning.
annaleigh
Apr 23, 2015 03:14 PM
norts1138
Jun 30, 2014 09:16 PM
Schlurch
May 7, 2014 06:28 PM
vibrancy
Mar 28, 2010 08:35 AM
Racerdave
15
Mar 10, 2003 07:42 PM
