Transmission/Power steering fluid question?
The owners manual calls for Mercon ATF for the power steering and Mercon SP ATF for the transmission. Will Valvoline Maxlife Dex/Merc ATF work for both? It says it is compatable with them or should I go to the dealer and get the specific fluids for each. Have not found a store that sells the specific product they are all blends. Thanks!
No matter what any manufacture claims or their marketing department prints... no fluid can truly be "multi-spec'd" and perform 100% as it should.
I personally only use standard Mercon V fluid (single spec) in my power-steering system and only use Mercon SP in the tranny. Yes, Merson SP and Mercon LV are now compatible for the tranny, I just prefer to use Mercon SP as long as it is available so as to only have one type of fluid in my tranny... and since it has worked so far for 211,000 miles, why change now?
Mercon V has replaced Mercon and is 100% compatible, since the Mercon spec was discontinued by Ford... so even if yor manual (like mine) states to use Mercon in the P/S system, Mercon V is just fine (but not SP, LV or any other spec).
I also run a Magnafine in-line P/S filter (it's a tranny and P/S filter) on my truck and believe that it has to help filter my P/S fluid. Just do a search for Magnafine P/S fluid filter install. The filter filters and has a built in magnet. Ford use to mandate their use when installing a rebuilt tranny.
Jesser02EX
11-14-2013 10:24 PM
villestrip
02-25-2009 11:16 AM
dalfollo
1997-2006 Expedition & Navigator
03-13-2004 03:43 PM
