Power Steering Flush?
Old Mar 13, 2014 | 03:57 PM
Oryo's Avatar
Oryo
I'm looking into doing a power steering flush to our 2005 F250 with about 95,000 miles.
I was just wondering I know it takes special transmission fluid and see here on the site that it takes Mercon V ATF but when I checked at the auto part store they tell me it takes Mercon LV?
They recommended me to use Valvoline Max Life Full Synthetic Multi-Vehicle ATF. They said it is recommended for Dex/Merc & Mercon LV.
Before I do anything I want to double check?
I found another local auto part store who carries the Motorcraft Mercon LV but again I want to double check?
Do I go with any of these or do I just go to dealership and just buy something from there?
Thanks again, Ory
Old Mar 13, 2014 | 04:22 PM
Oryo's Avatar
Oryo
I just found another auto part store that carries Vavoline Mercon V ATF & Castrol Mercon V?
I'm hoping to do the flush tomorrow
Old Mar 13, 2014 | 04:26 PM
npccpartsman's Avatar
npccpartsman
Originally Posted by Oryo
I just found another auto part store that carries Vavoline Mercon V ATF?
The power steering takes Mercon V. The transmission takes Mercon LV or SP. They are NOT compatible and should not be mixed.
Old Mar 13, 2014 | 04:45 PM
Oryo's Avatar
Oryo
So Valvoline or Catrol Mercon V would be ok? I wonder why the guy at auto part store when he checked his computer told me Mercon LV when I told him I was doing a power steering flush?
Old Mar 13, 2014 | 05:27 PM
npccpartsman
Because most autoparts stores don't have a clue what these trucks really need to be maintained correctly. That's why we're here.
There's also a BIG difference between a partsMAN and a parts clerk.
Old Mar 13, 2014 | 06:06 PM
Oryo's Avatar
Oryo
You had me laughing reading this!!!
Thank you so much for all the info and you're right! The reason I'm here because with this site I keep doing the correct things for my truck.. Thanks again!
Old Mar 13, 2014 | 10:13 PM
BLADE35's Avatar
BLADE35
I think a lot of guys are switching to a Compatible Synthetic fluid
Power Steering/HydroBoost Flush
Ford Super Duty Power Steering Flush | Superdutypsd.com
Power Steering/HydroBoost Filter
Ford Super Duty Power Steering Filter | Superdutypsd.com
Old Mar 14, 2014 | 10:09 AM
daddykitty's Avatar
daddykitty
what about this one from amsoil?
AMSOIL Signature Series Multi-Vehicle Synthetic Automatic Transmission Fluid
Old Mar 14, 2014 | 01:51 PM
bbender85's Avatar
bbender85
do these links apply to the 6.0l too?
Old Mar 14, 2014 | 02:43 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Here is a video of the steering flush on a 2004 6.0L. It's better if the front wheels are off the ground. This truck was parked on gravel.
Old Mar 14, 2014 | 04:39 PM
IHbase's Avatar
IHbase
As I recall, the guy in that video made a mess. I ran a clear line from the brake booster to a container on the ground and crimped the old line running to the ps reservoir. This way, nothing leaked anywhere and I could see when the fluid ran clear while I added fluid. I did not bother to lift the front end off the ground but did turn the steering box to help flush.
-Mike
Old Mar 14, 2014 | 05:36 PM
amdriven2liv
-Mike
Yes he did. He didn't put the line he disconnected at a higher level. You can see a moist area by the cowling.
FUJINAMI1293
34
Oct 17, 2012 02:11 PM
joeyd61
May 10, 2011 02:15 PM
UaVaj
Jan 9, 2011 06:04 PM
Bigol350
Nov 25, 2009 02:26 PM
dalfollo
Mar 13, 2004 03:43 PM
