Insulation Cover/plate???
Old Feb 16, 2012 | 03:20 PM
F250 H D Girl's Avatar
F250 H D Girl
Can anyone give me some ideas???? About 3-4 years ago I had someone put in a new clutch/pressure plate and flywheel in my 1997 F250 Diesel, 4 speed with overdrive, well to say the least it works great, however the noise I'm getting coming through the floor around the gear shift I have to keep a heavy blanket wrapped around it to even hear the radio, apparently he forgot to put some kind of insulation cover back up under there (so he says, which he also threw away) and I need someone to tell me what & where I can buy this piece that goes back in there.
Old Feb 16, 2012 | 03:36 PM
Hussler's Avatar
Hussler
Here is a recent thread about that very subject ...
https://www.ford-trucks.com/forums/1...-rollover.html
Old Feb 17, 2012 | 07:32 AM
F250 H D Girl
Insulation Cover/Plate???
This is some really great information but I don't think it's what I'm looking for. Inside my truck under the gear shift boot is a plate and then there is nothing, I needed to know if there is some other kind of plate or insulation cover that is suppose to be installed from the bottom to keep all the noise from the outside elements from coming in from under there. If I keep the heavy blanket wrapped around the bottom of my gear shift/boot it is all quiet, but the moment you take the blanket away it is very noisy coming from the space by the boot. The mechanic even told me that he had forgotten to put this cover(????) back under there.
Old Feb 17, 2012 | 07:42 AM
fordpride's Avatar
fordpride
Then I'd say it should be up to him to get one and put it on.
Old Feb 17, 2012 | 07:50 AM
F250 H D Girl
That's easier said than done, haven't spoke with him in 3 years and I'm not sure where he is now. I find it better to try and find the thing and do it myself. I thought that maybe someone might know what I'm talking about and direct me to finding it.
Old Feb 17, 2012 | 08:01 AM
Lazy K's Avatar
Lazy K
Can`t be much help other than to suggest you go to partsguyed.com and enter your truck details and then look for something like transmission tunnel insulation or transmission tunnel access cover.
Old Feb 17, 2012 | 08:30 AM
F250 H D Girl
It gives me a starting point to look somewhere. I appreciate any input I can get.
Old Feb 17, 2012 | 08:40 AM
fordpride's Avatar
fordpride
Inside the black boot should be a white insulator to help keep the noise out
Old Feb 17, 2012 | 08:44 AM
F250 H D Girl
That's not there, when I pull the boot back all I see is a black metal plate, no kind of insulated base. I'm not having any luck with a website to find this particular part, any suggestions where to look?
Old Feb 17, 2012 | 08:53 AM
fordpride's Avatar
fordpride
Here ya go
https://www.ford-trucks.com/forums/1...-boot-zf5.html
Old Feb 17, 2012 | 08:59 AM
Talyn's Avatar
Talyn
Shes talking about the white boot under the shifter boot to reduce noise.
Id double check your fluid levels too. The trans gear rollover will be louder if there is not enough oil.
Old Feb 17, 2012 | 09:00 AM
fordpride's Avatar
fordpride
LMC Truck Parts - Page 105
krewat
Modular V10 (6.8l)
Jul 17, 2020 04:05 PM
86F250 460
Apr 19, 2018 07:28 AM
66with352
Nov 10, 2017 05:07 PM
Rustyol79
Apr 25, 2017 11:12 PM
