Old 11-13-2014, 06:25 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Air Intake and Exhaust Guides
Print Wikipost
K&N Air filter worth the investment?
Old 02-16-2012, 08:03 AM
Big-Red-Lariat's Avatar
Big-Red-Lariat
Big-Red-Lariat is offline
My 5.0L has been almost 1yr on the road and thinking of changing the air filter...never owned a cleanable & reusable one. $54 for a K&N at JC Whitney, and the aftermarket paper ones range from $7-$12.00 on EBAY.
So i can get 7 paper ones for 7 years of use for about the same price as a K&N, and after that I will probably get a new vehicle...so is there some other advantage to these? I read the K&N FAQs and don't see much if any price benefit. Am I missing something?
EBAY
Ford 7C3Z-9601-A Motorcraft FA1883 Baldwin PA4323Manufacturer Part Number: CA10262Other Part Number: Hastings AF1333 Napa 9883 Wix 49883 Puro. A35642
FRAM Part Number CA1026
Product Type Flexible Panel Air
Product Height 2.64"
Product I.D. 9.93" (Width)
Product O.D. 10.48" (Length)
Competitor Cross Reference
BALDWIN PA4323
CARQUEST 83883
DEFENSE DA10262
DEFENSE DA10262
FORD 7C3Z-9601-A
HASTINGS AF1333
MICROGARD MGA10262
APPARENTLY FITS
F150-350
V10-6.8L F/inj. (30V) SOHC (Y) [2010-2008]
V6-3.5L D.I. ECOBOOST Twin-Turbo (T) [2011]
V6-3.7L F/inj. (24V) DOHC Flex Fuel (M) [2011]
V8-4.6L F/inj. (16V) SOHC (W) [2010-2009]
V8-4.6L F/inj. (24V) SOHC (8) [2010-2009]
V8-5.0L F/inj. DOHC Flex Fuel (F) [2011]
V8-5.4L F/inj. (24V) SOHC (5) [2010-2008]
V8-5.4L F/inj. (24V) SOHC Flex Fuel (V) [2010-2009]
V8-6.2L F/inj. (6) [2012-2010]
V8-6.2L F/inj. Flex Fuel (6) [2012-2011]
Old 02-16-2012, 09:00 AM
emboyd's Avatar
emboyd
emboyd is offline
Years ago, I had a K&N filter on my '91 5.0L Mustang. I'm not sure I would want to have another one, though, since it takes time to properly maintain them. If I had other reasons to improve the "breatheability" of my intake system, such as forced induction, then I may consider it. But, for a daily driver, I think I'll just stick to paper filters. I don't have extra time to devote to the cleaning process. Also, the K&N may be re-usable, but you still have the "maintenance cost" of the K&N Filter Oil and Cleaning Solution.
Old 02-16-2012, 11:19 AM
tvsjr's Avatar
tvsjr
tvsjr is offline
They're a pain to clean, over-oiling can lead to MAF fouling and other fun, and they've been shown to allow larger particles of dirt through (and that's if you oil them properly). And they're a mess to clean.
I run Motorcraft or Wix paper filters and they function just fine...
Old 02-16-2012, 11:27 AM
04XLTRUNNER's Avatar
04XLTRUNNER
04XLTRUNNER is offline
STAY AWAY..... MAF and k&n oil does not get along at all.
Old 02-16-2012, 11:28 AM
04XLTRUNNER
If you want to get a "cold air kit" i would go with a voolant. I had one on my 2005 and loved it. I would have one on my truck now but havent came up with the money to buy it.
Old 02-16-2012, 03:44 PM
shotgunz's Avatar
shotgunz
shotgunz is offline
Yeah - just stick with the MC paper filter. Per the maintenance guide I only have to replace mine every 30K miles.
Is the 5.0L different?
Old 02-16-2012, 08:29 PM
stephen.osborne1's Avatar
stephen.osborne1
stephen.osborne1 is offline
Unless you are running forced induction, you won't benefit performance wise from a K&N on these new trucks (or a so called cold air kit for that matter...) and even then you are risking destroyed impeller blades from the increased dirt allowed into the intake. And if not oiled properly, you will gum up your MAF sensor, causing poor performance and mileage. I like the cold air and K&N filter on older vehicles with natural aspiration, but not on my newer vehicles.
Old 02-16-2012, 08:43 PM
cnvF250's Avatar
cnvF250
cnvF250 is offline
I have 185000 miles on my 2002 f250 with the V10 and have had the same K&N airfilter on it without any MAF issues. It is the original. It is always clean. Yes there is maint. on it but it really isn't too bad. They are correct about over oiling it. Don't do it. If you follow the directions it is pretty easy to right.
Old 02-17-2012, 04:07 AM
shotgunz's Avatar
shotgunz
shotgunz is offline
Chris - consider yourself lucky.
Here is a test on Bob is the Oil Guy: Air Filtration Test K&N fails to even get close to it's marketing hype.
And here's diesel testing: http://www.dieselbombers.com/chevrol...r-testing.html Once again, K&N is a total failure at filtration.
Old 02-17-2012, 06:39 PM
cnvF250's Avatar
cnvF250
cnvF250 is offline
Wow, I am a information junkie and hadn't found that before. Good read. Maybe I was lucky. Here I thought I was getting better mileage and all that related to the filter. It must be my driving habits.
Old 02-17-2012, 06:58 PM
Greg B's Avatar
Greg B
Greg B is offline
Save your money. The gains aren't there, especially in the rpm range we normally use our trucks.
Old 02-18-2012, 04:40 PM
Gary Atsma's Avatar
Gary Atsma
Gary Atsma is offline
Someone a few posts earlier mentioned the Volant unit. They are now making units with the Donaldson PowerCore element that is the same type as used from the factory in the Powerstroke Diesels since about '03. A VERY good filter with very little restriction. If you're looking into aftermarket units you could do a lot worse than that unit.
Old 02-18-2012, 06:11 PM
tvsjr's Avatar
tvsjr
tvsjr is offline
The Donaldson filters are pretty impressive... and the amount of dirt they can hold is incredible. Something like 2lbs. of dirt before they are restrictive enough to trip the filter minder. Unfortunately, they aren't cheap... but it would mean substantially less time under the hood.
Old 02-18-2012, 07:12 PM
Greg B's Avatar
Greg B
Greg B is offline
Donaldson filters are about the best on the market. They are used in the M1-A1 Abrams tanks. We also use them on our compressor packages. Not cheap, but top shelf all the way. Put a K&N on my 05 PSD F250 6.0L. I had it on the truck for exactly 1200 miles (1 trip) and it came off. I never used it again. I went back to the stock Donaldson.
Old 02-18-2012, 07:45 PM
Big-Red-Lariat
Thanks for the advice boys---just had 3 FRAMs delivered to my door from AMAZON for $10.00 ea & change...these will last me well into 2015, then time for a new truck!
3 "Fram CA10262 Extra Guard Panel Air Filter"
Automotive; $10.56
In Stock
Sold by: Amazon.com
Quick Reply: K&N Air filter worth the investment?
