Sponsored by: Real Truck
550- Death Wobble!!
Old Feb 15, 2012 | 10:32 PM
L&D's Broncos's Avatar
L&D's Broncos
Die Hard Ford Fan
550- Death Wobble!!
Trying to figure out a 2006' F-550 2WD that has 135,276 miles and carrying 21,000 ALL the time, (service truck)
Been noticing last several 1,000 miles front end has had a shimmy in the wheel while passing 40-going to 50. After 50 going up to 65-75 it is basically gone. Last week we serviced it and rotated tires and checked air pressure, now going up on ramp to interstate you had better be wide open or when it gets to 44-45 front end takes a s#%^& fit.
Jacked it up and checked ball joints, tie rods and drag link. Everything is tight. Tires about 1/2 worn, running 90 in fronts. ( LRE- you can run 110) Tried 100- it gets worse. Pretty sure it's tires but what has anyone here found??? Track bar is tight on both ends too.
Old Feb 15, 2012 | 10:36 PM
joe_r_dog's Avatar
joe_r_dog
see how the shocks are. also, dual steering stabilizers help usually.
Old Feb 15, 2012 | 10:45 PM
LSchicago2's Avatar
LSchicago2
My 05 F450 had this and it was cured by replacing the front tires. Take 2 of the rears and swap them to the front. That will let you know if it's the tires or not for free.
Old Feb 15, 2012 | 10:48 PM
critterf1's Avatar
critterf1
He said he already rotated the tires. Stabilizer may well be the problem, probably worn out. A dual one is not really necessary.
Old Feb 16, 2012 | 12:40 PM
joe_r_dog's Avatar
joe_r_dog
Well most people put dual kits on 8000lb trucks and his is 21000lb. I've heard one isn't enough and 2 is almost overkill
hydro man 17
Oct 6, 2014 11:08 AM
Great Danes
6.7L Power Stroke Diesel
19
Apr 12, 2014 07:35 AM
Godfather15228
Sep 5, 2010 09:00 PM
tacurt
Apr 17, 2010 09:44 PM
DCRB
Aerostar
15
Oct 18, 2008 04:42 PM
