P0340 Code
Old Feb 15, 2012 | 05:02 PM
Eatonpcat's Avatar
Eatonpcat
P0340 Code
Who knows where the Cam shaft and Crank Shaft Sensor is on a 2004 F-150 5.4 cid
Old Feb 24, 2012 | 01:57 PM
xxnumbxx's Avatar
xxnumbxx
I have ran into this a couple of times, try clearing the code and unplugging the alternator. Road test the vehicle and see if the code returns, if it does not, the alternator is the likely cause. There is an issue with a diode inside the alternator failing and causing the pcm to trigger the MIL. Another possibly is the cam sensor itself and/or a timing issue. The timing chain or cam sprocket pins can fail. Does the truck run ok?
bellinoracing
2004 - 2008 F150
33
Sep 11, 2019 08:56 AM
boatman33
EcoBoost (all engine sizes)
Sep 7, 2018 07:59 PM
AFMSgt2012
2004 - 2008 F150
Aug 6, 2012 06:05 PM
meh129
1997 - 2003 F150
Mar 13, 2005 07:45 PM
