anti-lock
Old Feb 15, 2012 | 12:07 PM
fonedude1003's Avatar
fonedude1003
anti-lock
just bought 1989 f250 , anti-lock brake light has been coming on , also think i have a short or bad ground in turn signals , any ideas ?
Old Feb 15, 2012 | 01:19 PM
fordiesel69's Avatar
fordiesel69
Do you have rear abs only or do you have 4 wheel abs?
Explain in detail why you beleive there is a short in the turn signals.....
In 89, there is a connector near the the left tail light inside the frame rail that many times goes bad. It is round with another small single wire ground connector as well. These get water in them and corrode.
As far as ABS, either a ford dealer or a very good shop can scan it for you. It takes a dedicated scanner. If rear ABS only, swap the pickup sensor and go no further without a scan. If 4 wheel ABS, then do not swap out parts, it gets too expensive.
Old Feb 15, 2012 | 03:27 PM
fonedude1003
rear ABS only , and the fuse has blown on the turn signals twice...
Old Feb 15, 2012 | 03:29 PM
fonedude1003
thanks for the heads up on the connector in the frame rail , i will check that out first...
Old Feb 15, 2012 | 03:48 PM
Ole' gray's Avatar
Ole' gray
when ever your brake fluid is low, that light comes on.
Old Feb 15, 2012 | 06:27 PM
hdbear's Avatar
hdbear
yo
lots of good info on here....no
Old Feb 15, 2012 | 06:57 PM
fonedude1003
Thanks for the info Ole'Gray...
Old Feb 15, 2012 | 07:04 PM
rla2005's Avatar
rla2005
How to check for RABS codes yourself: FSB Forums - RABS Troubleshooting
Swisspsd
Jul 20, 2018 04:18 PM
jackstraw
Nov 12, 2017 05:55 PM
Bill4042
Oct 14, 2011 04:00 PM
Superlead777
Aug 30, 2004 04:07 PM
captntim
Dec 10, 2002 07:36 AM
