ABS acting up
Old Dec 8, 2002 | 02:54 PM
captntim's Avatar
captntim
ABS acting up
Old Dec 10, 2002 | 12:17 AM
RedLariat's Avatar
RedLariat
ABS acting up
Alright, my rear ABS light is always on in my truck, so I'm just assuming that the rear abs stopped working a long time ago, which is fine with me. But lately when I press the brakes (even lightly, on dry pavement) I can feel the abs come on. Is there anything to check on this? Is there a way to disconnect the abs all together? Any advice is appreciated.
Thanks
- Rob
'90 F-150 XLT Lariat
32" BFGs
A few Lund accessories
CB with 6' antenna
Old Dec 10, 2002 | 07:36 AM
steve83's Avatar
steve83
ABS acting up
You can disconnect it by pulling the fuse, or pulling the connector off the valve in the L frame rail under the brake booster and the light in the dash. If you want to fix it, pull the codes - Haynes tells how.
