EGR to remove or not remove ?
Old Feb 15, 2012 | 08:15 AM
revans9295's Avatar
revans9295
on my 1990 f-250 4x4 with a 351w . i am taking the smog stuff off of it . on the passenger side exhaust manifold is where the EGR goes into it. do i remove the EGR and plug it OR leave it hooked up so the computer can read it ?
Old Feb 15, 2012 | 10:10 AM
SCRebel's Avatar
SCRebel
I got rid of mine. And got the RJM Egr eliminator and block off.
To tell the truth I can't tell a difference, in mpg or power.
Old Feb 15, 2012 | 11:33 AM
Freightrain's Avatar
Freightrain
I highly doubt you would see a major improvement in anything by removing the EGR. Unless it was really screwed up/broken, leave it be.
All it does is allow some spent gas fumes back into the motor to reburn. Not exactly a performance improvement device, but doubt you'll see any seat-o-pants difference.
Old Feb 15, 2012 | 11:37 AM
revans9295's Avatar
revans9295
So I will leave it. Do I leave everything hooked up to it ?
Old Feb 15, 2012 | 11:46 AM
Freightrain
I'm guessing the sensors need to be there so it doesn't throw codes.
Old Feb 15, 2012 | 11:50 AM
Edgethis's Avatar
Edgethis
The sensors will need to be there to male the computer happy. Supposedly removing the EGR will hurt Mpgs. I replaced and kept the EGR when I did my headers.
Old Feb 15, 2012 | 12:03 PM
andym's Avatar
andym
Keep it if you can. It helps with mileage and emissions. It does absolutely no harm to the engine's performance.
Old Feb 15, 2012 | 12:06 PM
blkF250HD's Avatar
blkF250HD
The EGR reduces NOx emissions by lowering combustion temperatures. The EGR valve only opens while at steady cruise (the highway), so you will see no gains from removing it. By displacing fuel and oxygen it also improves fuel economy.
bigcountryfs
6.4L Power Stroke Diesel
Sep 24, 2011 06:24 PM
cooploops
Jul 16, 2008 08:28 PM
kellar
Aug 30, 2007 10:39 PM
Red96F150
Dec 1, 2004 07:40 PM
