what is it called??
Old Feb 14, 2012 | 12:41 AM
Plain Jane's Avatar
Plain Jane
what is it called??
Just replaced my PS gear box, PS pressure and return lines. After I was done I started looking at some of the other metal connected lines in the engine compartment and decided to give the new line wrenches a work out and replace all of them as well. I cannot find the smaller metal connection lines that attach to the radiator because I do not know the precise names of them, can anyone provide a little guidance here?
Thanks, Phil
Old Feb 14, 2012 | 01:10 AM
f100beatertruck's Avatar
f100beatertruck
Transmission cooler lines?
Are there two and do they both connect, one above the other into one of the tanks on the side of the radiator? The other ends will go to your automatic transmission.
Classic tube probably has pre-bent lines or most people just make them from sections of store bought tube.
Old Feb 14, 2012 | 07:02 AM
Edgethis's Avatar
Edgethis
+1 on the trans cooler lines.
Old Feb 14, 2012 | 10:43 AM
Plain Jane's Avatar
Plain Jane
Thank you! I typed in transmission lines and radiator lines in to the advanced auto parts & napa websites and got all incorrect items. will try again. Thanks.
Old Feb 14, 2012 | 12:00 PM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
If you want replacement metal transmission cooler lines you will have to goto LMC truck or a specialty tubing supplier.
Box Shop parts houses are only going to have components to build them with.
-Enjoy
fh : )_~
scottddove
Feb 9, 2012 07:21 PM
smashclash
Dec 6, 2010 06:16 PM
BlackNGoldRules
1983 - 2012 Ranger & B-Series
Jul 19, 2008 08:45 AM
stepasideman
Jun 17, 2005 05:42 PM
CT
Sep 7, 2003 12:20 PM
