Help with trans swap issue
Old Feb 13, 2012 | 10:40 AM
Shanejet's Avatar
Shanejet
I have a 99 F250 with 4r100. Swapped in a 4r100 from an 03 E350. Everything bolt up and works but shifting is not right. OSS on old trans is magnetic but on van trans the OSS is gear driven. Is it possible to tap the vss harness at the diff and splice into the oss harness. Both are supposed to be "hall" type senders. Will there be a voltage drop to contend with?
Thanks in advance.
Shane
Old Feb 13, 2012 | 01:57 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
If you splice into the VSS you probably will now have two bad signals instead of one. Also the VSS reads a different frequency than the OSS is expecting.
Old Feb 13, 2012 | 03:17 PM
Shanejet's Avatar
Shanejet
Yeah, that's what I was afraid of. What about a tuner or a pcm from a non psom van?
Old Feb 13, 2012 | 07:31 PM
Mark Kovalsky
A PCM might work. You might have to change the pinout of the harness. It might be easier and cheaper to change the trans to the right parts.
1320stang
1997 - 2003 F150
Dec 31, 2015 07:34 PM
Cmar88
Dec 20, 2015 09:00 PM
tonysmach1
Jul 18, 2006 09:04 AM
