trans swap
Old Jul 16, 2006 | 02:30 PM
tonysmach1's Avatar
tonysmach1
trans swap
Is it a bad idea to try a T5 swap in my 92150? I know crossmember, shaft, and 3rd pedal need to be fabbed. I wanted to change over from an AODE. Is this at all possible??
Old Jul 16, 2006 | 04:53 PM
lostin90s's Avatar
lostin90s
I'd find a manual donner truck ,to borrow the peddles and computer , trans,. as well as steering column. To Start with. Fabing stuff take alot more $ in the end. but if you got time anythings possible.
Old Jul 16, 2006 | 08:59 PM
Cheggie's Avatar
Cheggie
Bleagh! Put an M5R2 or a ZF in there! The T-5 is a car transmission. The gear ratios are all wrong, and they're not meant for hauling the weights that a truck can haul.
Old Jul 18, 2006 | 02:35 AM
tonysmach1's Avatar
tonysmach1
the reasoning behind this is that I do have a T5 sittin in the closet and ive been having trans problems. However I did secure a trans from a cargo van that has a wiring harness(2 plugs), how do I tell what kind and if it will fit my 5.0? thanks tony
Old Jul 18, 2006 | 09:04 AM
Kemicalburns's Avatar
Kemicalburns
i agree that tranny is all wrong for a truck. you could sell it easily though to any mustang nut. the m5 trannies are garbage to so figure on a zf or np435. is this a 2wd or 4wd truck
