Edge cts questions
Old Feb 13, 2012 | 08:43 AM
katesdad's Avatar
katesdad
Edge cts questions
I have been looking at these. Truck is a new 2012 so I do NOT want to program it. I would however like to view the various temps and gauge info it offers as well as add a backup camera. Are there any other options that offer this without programming? Also will this change anything on the truck (ie if I leave it stock can I unplug it and no trace left)? I don't want to void my warranty. Thanks
Old Feb 13, 2012 | 09:21 AM
gsxr1300's Avatar
gsxr1300
yes edge cts insight is what you want
i have one and its great
Old Feb 13, 2012 | 09:30 AM
katesdad's Avatar
katesdad
I see the insight model now. I think this is exactly what I want. This is not a programmer is it? It's just a gauge display-correct? Thanks
Old Feb 13, 2012 | 09:31 AM
gsxr1300's Avatar
gsxr1300
yep just a guage
Old Feb 13, 2012 | 09:37 AM
gsxr1300's Avatar
gsxr1300
Autoplicity.com. Edge Products Insight CTS Monitor - 83830
this is about the cheapest place to order it
I got mine from them
Old Feb 13, 2012 | 09:52 AM
jack_pine's Avatar
jack_pine
How do you install this unit?
Old Feb 13, 2012 | 09:53 AM
gsxr1300's Avatar
gsxr1300
it just plugs into the obdII port under the steering wheel the suction cup to the windshield
Old Feb 13, 2012 | 09:57 AM
jack_pine's Avatar
jack_pine
cool, thanks. I may have to sneak this into the house.... guess she is going to notice it when attached to the windshield, though.
Old Feb 13, 2012 | 10:00 AM
golfmedik's Avatar
golfmedik
Yep, it plugs into the OBDII port. You can even get a guage pod, paint it to match interior and install it like the one below. Although mine is '10, nearly identical. After painting, it took all of 15 minutes to install and program to the parameters I wanted to see.
Old Feb 13, 2012 | 10:14 AM
jack_pine's Avatar
jack_pine
Very nice. To echo one of the other questions...this is a display unit only, right? (no programming) I also don't want to mess with the warranty.............
Old Feb 13, 2012 | 10:15 AM
gsxr1300's Avatar
gsxr1300
yes display only
Old Feb 13, 2012 | 10:19 AM
golfmedik's Avatar
golfmedik
Yes..display only. No need to worry about warranty. Just make sure the service department knows its only a monitor to avoid an argument
Old Feb 13, 2012 | 10:47 AM
kper05's Avatar
kper05
I think it can control a tuner were you to connect an edge tuning device to the truck.
Without the tuning module, the device is only a monitor.
The power buttons at the top are disabled.
I simply unplug it when I take the truck in because I clean everything out of my truck anyways.
I use the suction cup to the center of my windshield above the tray to the right of my GPS.
This way when the hot sumer sun causes the cup to release, it only falls a half inch to the dash.
Spend the extra money to get the CTS.
You can put up to 8 PIDs.
Also, verify with them the 2012 model year works.
I read awhile back the 2012's weren't working properly.
Old Feb 13, 2012 | 11:12 AM
jack_pine's Avatar
jack_pine
Does anyone have this on the 2012 yet?
Old Feb 13, 2012 | 12:26 PM
Painted Horse's Avatar
Painted Horse
It works on the 2012, but you will have to download the latest software.
Edge has also announed the Evolution CTS. which IS a programmer and uses the same display panel. The INSIGHT is only a monitor The EVOLUTION is the programer.
Sitting on your dash they will look almost identical except for what come up when you push the buttons.
If you only want the monitor make sure to buy the Edge Insight CTS. Plus the Insight is $200 cheaper than the Evolution.
