AE contribution balance question
Old Feb 12, 2012 | 10:55 PM
run6.0run's Avatar
run6.0run
Is it normal for the line to dissappear when I hit the throttle? I can only see the line at idle. It does "flow" so I think its working. When I increase rpm's I can see the line spike up then it takes about 30 to 45 secs to return.
Old Feb 12, 2012 | 11:11 PM
zhilton's Avatar
zhilton
That's what mine does. I thought if I held a steady idle the line would return...but it still stays in the stratosphere of the graph. I forget who was having a hard time finding a shudder under load/acceleration and he tried the same thing...couldn't see the line once he took the truck off idle.
Old Feb 13, 2012 | 07:12 AM
Jimbob8's Avatar
Jimbob8
I've run it at higher RPM by setting RPM in grid screen, then switching to OBT screen & initiate test. When finished, hit done, then grid screen & you have to hit RPM twice to regain control.
I get a VIN not reported error, when trying to view, do ya'll get VIN? I keep thinking something is wrong with PCM, any ideas.
Old Feb 13, 2012 | 07:20 AM
run6.0run's Avatar
run6.0run
The only time mine doesnt get the vin is when I dont have the key on. So dunno about pcm. I could only get rpm's to be overridden to 1200. You guys seeing the same
Old Feb 13, 2012 | 07:28 AM
Jimbob8's Avatar
Jimbob8
I can only get 1200 too. Higher setting gets a few RPM, 5 or so.
goosehunta
Dec 24, 2013 04:25 PM
GOT
Apr 3, 2011 09:09 AM
79broncojosh
Feb 4, 2011 11:28 AM
nvreloader
Jan 23, 2010 01:10 PM
Monica
Nov 13, 2004 10:37 AM
