Temperture problems
Old Feb 12, 2012 | 10:03 PM
CRosdahl's Avatar
CRosdahl
Temperture problems
2003 7.3 the dash gauge says normal the computer says -40. Where would that sensor be located.
Old Feb 12, 2012 | 10:09 PM
joe_r_dog's Avatar
joe_r_dog
now i know this isnt a 6.0 which is much more important to have the digital guge 4, but i hate the dash gauges and i dont think they do anythin more than act as a warning light. others may disagree, but 6.0 owners will agree with this. i suggest getting something like a scangauge2
Old Feb 13, 2012 | 11:33 AM
powerstroke72's Avatar
powerstroke72
Moved to the 1999 - 2003 7.3L Power Stroke Diesel forum.
Maybe the forum mod for this section can combine your two threads on the same subject. I didn't realize you had two until just now. Best of luck with your issue.
Old Feb 13, 2012 | 12:07 PM
PaysonPSD's Avatar
PaysonPSD
If you have an automatic the temp you see on the computer is not reading coolant temp. Ignore it. It can range all the way up to about 400° and then drop back down and start climbing all over again.
I installed an after market coolant gauge so I could actually see the temp in degrees and not rely on the in dash temp gauge.
To answer your question the coolant temp sensor is on the top of the water pump.
jfuller429
13
Nov 20, 2023 03:15 PM
ctruf1504x4
Jul 20, 2019 03:44 PM
Hitagain
Mar 22, 2016 07:19 PM
bcaughhorn
Jul 2, 2015 06:35 PM
hornychief
1997 - 2003 F150
Jan 28, 2014 08:23 PM
