Welcome to FTE, Best Damn Forum EVER!
Here's How to Post Pictures:
1. Login to FTE.
2.Click User CP (In the Top Left Hand Corner)
3.(On the Left, There will be a list, The 5th Option Down, will say "Pictures & Albums) Click That.
4.Then, Click Add Album, Enter a title, and description, if ya want to.
5. Click Upload Pictures, Then click Browse, Locate the Files of your truck. (You can add 3 files at a time)
5. Click Upload.
6. Add a description to the individual pictures, then click save.
7. Add more files if ya want.
8. Click The Picture you want to post, it will give you two codes at the bottom, Right Click The Second one (It say's BB Code, Then Say's [IMG]http:blahblahblah...[/IMG])
Then, Once that is highlighted, Right Click, Then Copy, Then Paste it into your post.
You can add up to 30 Images in one FTE Post.
If, Ya need any help, Don't hesitate to ask.
Quote:
Originally Posted by old_dan
You can also go to the "Garage" tab and start an album right here on FTE. After you post pictures to an album, we can look in your album, but you'll also be able to "insert a picture" by pasting in a link to the picture in your album.
It seems awkward, but whenever you "insert a picture" to one of these threads, the forum is looking for the picture somewhere on the web (which is always available) rather than from somewhere on your hard drive (which isn't always available).
Man that's a nice truck. Ya the pic's aint easy by any means. I just had to print out the instructions that I keep posting because I was trying to use the old system and it won't work at all for me. But I got the album updated after several hours of resizing and uploading. Now I'm hungry.
I am not doubting what you say. Both mine and my Grandpa's F250's have factory throttle cables that were never installed in F250's . Anything is possible.
I talked with the origional owner and he said nothing has ever been changed.
His memory has failed him, because ONLY 1958/64 FE engines have an oil fill tube, which means the intake manifold is not original to your truck.
1958/64 FE (Passenger Car only) engines also have rounded valve covers with no holes in them for oil caps or a smog valve.
1965/76 FE engines have pent roofed shaped valve covers with holes in them for oil cap/smog valve. 1965 was the first year FE engines (1965/67: 352 / 1968/76 360/390) were installed in F100/350's.
So, from the pic you posted, the valve covers are correct for your truck, but the intake manifold is not...since it has an oil fill tube.
Originally Posted by 66Custom Cab
The radio looks like a transplant from another vehicle.
OP is in Canada. If this truck was assembled and sold new in Canada, the radio is correct.
Originally Posted by 1972RedNeck
Both mine and my Grandpa's F250's have factory throttle cables that were never installed in F250's.
I'm going to have to look into deeper when the manifold was changed and this is a Canadian truck. From everything else you saw do you think this truck is up to a total restore? I don't want to sell it but just to have.
