Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
F 600 FUEL PROBLEM
Old Feb 12, 2012 | 04:55 PM
pinn600's Avatar
pinn600
F 600 FUEL PROBLEM
While loaded with 6 ton of gravel,my 68 F 600 with 330 2 bbl,near top of a long ,full throttle grade,began coughing and sputterring.Letting up on accelerator seemed to help.On next long grade,same thing but on level ground in between pulls it ran fine.Seemed to clear up alltogether before getting home.Does anyone think this sounds like trying to vapor lock?Or maybe bad fuel?Thanks for all help.
Old Feb 12, 2012 | 10:45 PM
85e150's Avatar
85e150
Sounds like the fuel pump not keeping up.
Vapor lock isn't going to go away when you lift the throttle.
Bad fuel isn't going to clear up when you lift the throttle.
Have you checked the fuel filter? A partially clogged filter could contribute to this methinks.
A fuel pressure test might be in order. 7 psi rings a bell for fuel pressure, but I'm not sure on that.
Old Feb 13, 2012 | 04:36 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
As original, corrogated paper cartridge fuel filter fits into a cannister that threads onto the fuel pump.
Peeps are unaware, install in-line fuel filter. And because they are unaware, cartridge fuel filter is getting more clogged up everyday because...it hasn't been changed...in how long?
C4AZ-9365-B .. Cartridge Fuel Filter (Motorcraft FG-1A) / Available from Ford and autoparts stores.
Applications: Myriad 1964/77 FoMoCo vehicles.
Old Feb 14, 2012 | 06:26 AM
pinn600's Avatar
pinn600
F 600 fuel problem
Thanks for replies.Cleaned screen filter at carb. and had no problem next trip.Once again,thanks.
menze46
Oct 19, 2019 10:33 AM
fixxxer-upper
Dec 8, 2011 06:49 AM
BobbySmith
34
Feb 13, 2009 05:52 PM
sierra5.3
Jul 30, 2004 02:16 AM
thor825
Aug 10, 2003 09:14 PM
