fuel flow problem ?
Old Aug 6, 2003 | 04:35 AM
thor825's Avatar
thor825
fuel flow problem ?
hello there truckies,
new day new problem.i have an f-150 1987 lariat xlt fuel injected302.changed the fuel filter other day now periodicaly she shuts down in mid stride like it,s starving for fuel if i,m going fast enough she,ll pick back up but most times im on the side of the road cranking it a while until she starts back up.i have run it dry a few times(guages not working properly)but before i changed the filter that did, seem to be a problem.been told to drop tanks and check filter in bottom of tanks to blowing air back down feedlines any ideas i do have duel tanks switching unit seems to be working ok HELP!
Old Aug 6, 2003 | 04:44 AM
cgorris's Avatar
cgorris
fuel flow problem ?
Well sounds like you could have gotten trash into the fuel line when you changed the filter. Also, you may want to investigate possible throttle positioning sensor going bad. Could be just coincidence that it happened along the same time you changed the filter.
Old Aug 6, 2003 | 05:11 AM
mikey 0166's Avatar
mikey 0166
fuel flow problem ?
Hey thor,, I was just wondering,,,,,,, are you sure you didnt put the fuel filter on backwards,,,,, you said you didnt have the problem until you changed the filter,, right?? 2o years as an industrial maintenance tech has taught me that if you do something and you imediatly have a problem,,,, goe back and undo what you just did.I Could be wrong but just a thought
Old Aug 6, 2003 | 06:23 PM
woodstockaz's Avatar
woodstockaz
fuel flow problem ?
My truck is an '89 Ranger. It seems to bogg down when I give it gas too fast. I'm thinkin it is the fuel pump. I think it sounds like yours might be bad too. Have you done a fuel pressure test?
Old Aug 7, 2003 | 04:03 AM
thor825's Avatar
thor825
fuel flow problem ?
thats one of the first things i thought of i,m a plumber by trade and you cant go wrong with direction of flow arrow ->as far as fuel presure test good recomendation i did disconnect fuel filter and pump fuel into a can but i did not switch back and forth from front to rear while doing it.and not for an exstended time think chilton says i pint in 20 seconds.also i,m wondering if running it dry has,nt fouled up the fuel sox in the bottom of the tanks where the booster pumps are anyway i think i,ll start with a full presure test and work my way back to the tanks any other ideas greatly appriciated.
Old Aug 10, 2003 | 09:14 PM
steve83's Avatar
steve83
fuel flow problem ?
The only way to check the pressure is with a fuel pressure gauge attached to the port on the fuel rail on the engine. You can't tell by looking at the stream it sprays or how much it flows. Sears sells one for ~$20.
The fuel pump ALWAYS pulls from the bottom of the tank, so you didn't hurt it by running it dry once.
eds72
Jul 14, 2015 08:25 AM
hawgystyle
20
Feb 3, 2012 06:03 PM
BossFan
19
Aug 20, 2011 06:59 PM
BigRedFordTruck
May 16, 2010 02:34 PM
cruster
1983 - 2012 Ranger & B-Series
Jan 24, 2005 01:09 PM
