Rear drum removal?
Old Feb 12, 2012 | 03:11 PM
marine1200's Avatar
marine1200
Rear drum removal?
Do you need a puller or do I just need to whack the heck outta it?
Old Feb 12, 2012 | 03:46 PM
newold46's Avatar
newold46
A puller never hurts. See if the brakes are loosened up all the way (if possible) and see what happens when you whack it once or twice! If you liked it, whack it again! If that fails look for a 3 jaw puller so you don't warp the drums and get them stuck.
Old Feb 12, 2012 | 04:58 PM
46fordtruck's Avatar
46fordtruck
A puller for sure will make quick work of it. As mentioned, use a 3 jaw puller, that will pop the drum without hurting it. Also, back the shoes off, make sure they aren't frozen to the drum.
Old Feb 12, 2012 | 07:15 PM
newold46's Avatar
newold46
Look for some sort of locking type thing on one of the lug studs too. Sometimes they are there, sometimes not.
Old Feb 13, 2012 | 09:11 AM
mprsox's Avatar
mprsox
Smile rear drums
hi,
I have a 1940 one ton pickup, on my rear drums at the inside bottom there are two adjustment bolts, inside they have cams. also on the middle outside further up there are two more adjusting bolts which are also cammed.
i would try moving them a little too to see if you can unstick the shoes from the rotors.
rotors are hard to find for certain models, shoes are easier to replace.
i used a dead blow plastic or rubber coated mallet to loosen mine. then pried it open with a strong screwdriver. you can alwyas squirt wd40 in there too, since it is a take apart job, you can clean and dry the parts later. you can also squirt wd40 in the inside roller bearings if needed.
fyi, there is a shoe reliner company in houston called heitmans brakes, they do excellent relining on all types of drum shoes.
good luck, semper fi!
mpr
Old Feb 13, 2012 | 10:16 AM
christurney77's Avatar
christurney77
We kept giving the drum "love taps" with a hammer and two pry-bars opposite of each other. One side took a couple of minutes... The other side took probably 15 minutes.
Good Luck
Old Feb 13, 2012 | 02:22 PM
pete moffat's Avatar
pete moffat
axle problems
Be careful about whackin the axle I broke 2 axles, they crack and may let you down when you least expect it, one broke just befind the taper and I almost lost the wheel, I now have an old school hub puller found at swap meet. I'm restoring my 46 and need two good rear fenders....any ideas
Old Feb 13, 2012 | 05:13 PM
marine1200's Avatar
marine1200
Thanks fellas...its raining today so my journey shall continue tomorrow.
Old May 30, 2012 | 08:56 PM
pete moffat
drum removal
I agree that these shouldn't be whacked, I have had 2 axles fail at poor times, never abused, these axles are becoming really scarce. I found an old puller at swap meet and keep a stash of axles in case it happens again, in a rusty climate these tapered axles become....a pain in the axle!!!
Old May 31, 2012 | 08:00 AM
jailbar's Avatar
jailbar
I have one rear fender Left side in decent shape, do you want a picture? DO you live anywhere near Wisconsin?
JaiLbar
Old Jun 4, 2012 | 01:31 PM
schoo's Avatar
schoo
got my brake drums off yesterday after 3 weeks of pb blaster one bottle of propane, and hundreds of wacks with 3# hammer, now parts
this is a 1 1/2 ton so it has screws(bolts)counter sunk to hold drums to axle, where to get some any ideas. tried joblot, local napa..help
roy
Old Jun 5, 2012 | 11:08 AM
marine1200's Avatar
marine1200
I eventually went to Harbor Freight and bought a puller. Came off in 2 minutes.
Old Aug 12, 2012 | 06:52 PM
bread320i's Avatar
bread320i
I defently need a puller you speak of. What does a puller like this look like?
Old Aug 12, 2012 | 06:56 PM
marine1200's Avatar
marine1200
HERE IS THE LINK
3 Piece Three-Jaw Puller Set
Old Aug 12, 2012 | 07:02 PM
newold46's Avatar
newold46
You can usually get by with a plain-jane 3 jaw puller but sometimes you need the tool meant for the job. I used the one I linked and it was easy. Others have used the 3 jaw and had the same results. I guess it depends on how much you want to spend.
