New True Duals
Old Nov 22, 2015 | 02:26 PM
kaboom10's Avatar
kaboom10
Thumbs up
Originally Posted by johnday
LOL, I have enough trouble just showing photos!Q
In Waterford eh?
Think I'll do a bit more research on these guys, this is the first I'd heard of them. I had chambered exhausts on a '72 302 Comet GT years ago, sounded great. My Borla sounds great, but would like just a little more sound at idle and low rpm. This is the chamber I'm looking at to replace the resonator, the last one.
SHORT POWERSTICK Short POWERSTICK
IN/OUT PART# CORE BODY DIA. BODY LENGTH OA LENGTH
2" 2018SB 2-1/4" 3" 14" 18"
2-1/4" 22520SB 2-1/4" 3" 16" 20"
2-1/2" 2520SB 2-1/2" 3-1/2" 16" 21"
3" 3020SB 3" 3-1/2" 16" 21"
Looks like about $70, plus shipping, but I could just pick it up down there. Have to get under the truck again and measure the Borla resonator as well.
I like the guy. See him on factory five forum. I guess he sells a lot of mufflers for those kit cars. Guy knows his stuff. Loved talking to him when we met at a parts store parking lot. I have a couple of the 24 inch 2 1/2 dia. mufflers with an x pipe.
Old Nov 22, 2015 | 02:42 PM
Tedster9's Avatar
Tedster9
Originally Posted by kaboom10
I had an x pipe put in. Helps with the scavenging. I'll give u my phone number and let u listen that way. Used to be able to post but not now.
If you make it part of the answering machine recording we can all listen that way.
Old Nov 22, 2015 | 02:51 PM
kaboom10's Avatar
kaboom10
If they would fix their pic problem first. I like my phone answer as it is. I like my ringtone better. https://www.youtube.com/watch?v=P1w7Fh7VNto
Old Nov 22, 2015 | 05:58 PM
rsylvstr's Avatar
rsylvstr
In Waterford eh?
I have been emailing him and looking at the last one also. But since my truck has 2.5" pipe I'm thinking the 2520 instead. Didn't think a reducer would make sense.
Old Nov 22, 2015 | 06:24 PM
johnday's Avatar
johnday
I'm not familiar with the system on a 5.4. Are you talking about replacing the muffler, or the resonator, or both, if you have both.
Old Nov 23, 2015 | 12:31 PM
rsylvstr's Avatar
rsylvstr
Muffler.
That's all she has.
Old Nov 23, 2015 | 03:47 PM
rsylvstr's Avatar
rsylvstr
Any recs ?
2.5" with clamp to current 2.5" pipe.
Pipe goes from cat to current muffler.
Or
3" with reducer between the two?
Not looking for performance.
Just tone.
Have cold air intake and JNA shorty headers.
No programmer anymore.
Old Nov 23, 2015 | 05:24 PM
kaboom10's Avatar
kaboom10
Any recs ?
Or
Just tone.
If u r using a single pipe the bigger the better. Don't know if the noise will change but the less cylinders u have to quiet the harder it is.
Old Nov 23, 2015 | 08:51 PM
rsylvstr's Avatar
rsylvstr
yes, single pipe. wasn't sure what a reducer would do.
Old Nov 23, 2015 | 09:52 PM
kaboom10's Avatar
kaboom10
A reducer chokes flow but causes the velocity to increase.
Old Nov 23, 2015 | 10:24 PM
rsylvstr's Avatar
rsylvstr
Does it really matter which tube goes inside and which outside?
Old Nov 26, 2015 | 08:30 PM
rsylvstr's Avatar
rsylvstr
Ordered 3030sb. Will have shop install when they do the header gasket again. Damn felpro.
Classic Chambered Exhaust Inc. - Products
Old Nov 26, 2015 | 10:45 PM
  #28
kaboom10's Avatar
kaboom10
I'm surprised you say that about Felpro. When I was working at McCord gasket some engineers would say to use them for certain gaskets that were better than ours. I would go with an aluminum type gasket if available like Mr. Gasket's header flange gaskets. Alternatively use a graphite based gasket if you can find one. We had great sealing with them. Last would be a multilayered gasket like you find head gaskets made out of. Don't forget to have the pipe going to the muffler mounted where it has a little flex in it for the motor movement but to where therez no movement to hit the body or itz undercarriage components.
Old Nov 27, 2015 | 08:42 AM
  #29
rsylvstr's Avatar
rsylvstr
Thanks. Probably not justified but since the gasket only lasted three years i am not happy. I even brought it back to the garage after several days and several hundred miles so they can re-torque them.
ck4627
1983 - 2012 Ranger & B-Series
Oct 28, 2007 08:11 AM
428fourby
May 30, 2007 09:31 PM
Skandocious
Exhaust Systems
Nov 30, 2006 09:01 AM
Gary42141
Exhaust Systems
Apr 30, 2005 03:22 PM
Marc150
Exhaust Systems
Jan 27, 2004 03:55 PM
