Need quick UVCH help
Old Feb 12, 2012 | 02:15 PM
01PS's Avatar
01PS
So I got valve cover gaskets and UVCH harnesses from the Ford house. The Ford guy told me they didn't even have a part number for pigtails. So... I got to the pass side to find a badly burnt pin (gasket had a huge hole blown out). I am wondering if I should plug the old pigtail connector in to the new gasket or not. The GP pin is obviously discolored on the pigtail, but the Ford house is closed today and I HAVE to get my truck out of my buddy's shop today. Any help is greatly appreciated.
Old Feb 12, 2012 | 02:50 PM
01PS's Avatar
01PS
Took the connector apart and cleaned the discolored pin with DN alcohol. Pin looks good but I'll probably end up doing pigtails soon. It looks way worse than it is with the blue shell on there.
Other things we found while doing this:
Compressor wheel looks bad. I'll try to post pics later.
Turbo is leaking oil between the compressor and turbine housings. Pedestal is completely covered in oil. Again, will try to post pics when I get home later.
I'm really hoping the UVCH was responsible for the bucking at low throttle. The hole in the pass side gasket was awfully close to the injector pin. Both sides were backed out a bit so we did the 50 cent mod while we were in there.
3 bad GP's on driver side, and 2 bad on the passenger side as well as the burnt gasket and backed out connectors. The truck should start a lot better!
Old Feb 12, 2012 | 03:09 PM
PaysonPSD's Avatar
PaysonPSD
If you want to avoid any damage to the new VC gasket then just lift one of the small control leads off the GPR and it will not operate.
If it is cold to start without GPs plug in the block heater and have a few beers with your bud. Should be warm enough to start in a couple hours.
Old Feb 12, 2012 | 03:16 PM
woodnthings's Avatar
woodnthings
You can get the harness from Clay at Riffraff Diesel!
Riffraff Injector Harness Connector Pigtail
Old Feb 12, 2012 | 04:27 PM
01PS's Avatar
01PS
All new GPs installed so I think I'm good to go. Boost numbers are low on test drive. 17psi. Checked boot clamps, but turn out K&N still has so much water in it from cleaning it weighs about 5 lbs. Impatience does not pay off again.
Old Feb 12, 2012 | 04:28 PM
01PS's Avatar
01PS
Will end up doing that, but I was looking for a "quick fix" instead of driving in town to NAPA and paying $80+. The connectors cleaned off fine, wiring looks good, and all new GPs.
Old Feb 12, 2012 | 04:30 PM
01PS's Avatar
01PS
Noticed one of the 4 bolts between the center section and turbine housing was missing. That explains the oil all over the turbo. New bolt installed and new compressor wheel on the way with fuel bowl rebuild kit from Guzzle.
Old Feb 12, 2012 | 06:49 PM
Bonanza35's Avatar
Bonanza35
Good luck on the turbo but I think it mit be more then just the one bolt if the rest were tight. If so you can get a kit from Clay easy fix.
Chet
Old Feb 13, 2012 | 09:06 AM
01PS's Avatar
01PS
Man I hope not. I have a inquiry in to Ron's Turbo Service. The shaft play felt fine, and the bolt appeared to have backed out rather that snapping off. We threw a bolt in until I get the new ones from Guzzle site. The compressor spins free and doesn't seem like it's rubbing or anything. Fingers crossed.
Shake-N-Bake
36
Apr 3, 2020 10:44 AM
jtexfisher
Oct 2, 2011 04:14 PM
luny1
Dec 4, 2009 10:09 AM
97biostroke
Jan 20, 2009 09:21 PM
FLORESH
15
Dec 11, 2007 07:59 PM
