Trailer wiring help...
Old Feb 11, 2012 | 10:24 PM
ManicMike's Avatar
ManicMike
Looking to add the wiring to my truck
Tow Ready T-One Connector Wiring Light Kit 118316 Is that the correct T-connector?
Then I'd like to add this: Hopkins 7-Way and 4-Flat Multi-Tow Connector LM-47185
Also anyone have a good opinion on a brake controller? The trailer uses a 7-blade pin connector and is dual axle with electric brakes.
My buddy (the trailers owner) uses this one:
http://www.amazon.com/Tekonsha-90195.../dp/B000P17NXQ
He loves it, it's VERY smooth. I've been with him while towing and you can't feel when the trailers brakes engage/disengage.
Lemme here your opinions!
-Mike
Old Feb 12, 2012 | 06:45 AM
ncranchero's Avatar
ncranchero
Your light connector choices seem to be correct if the vehicle in your signature is the intended victim. Personally I'd cut/splice/solder/heat shrink the T-connector to the 4/7 trailer receptacle. Can't speak to the controller as I haven't used that one.
Alex from GA
All Things Towing
Jun 19, 2018 12:31 PM
ndlawrence
Jul 16, 2013 05:53 PM
Rlnewt10
Oct 29, 2006 03:36 PM
budhead1
Apr 21, 2006 08:57 AM
walkerfarms
All Things Towing
Oct 25, 2005 09:04 PM
