Bronco II Ford Bronco II
Running erratically
Old Feb 11, 2012 | 04:32 PM
krazymike's Avatar
krazymike
Smile Running erratically
I have a 1986 ford bronco II, 2.9 ltr 4x4. Ive replaced both fuelpumps, filters, gas cap, evp, map, ego, tp, egr, spark plugs, cap, rotor. The truck, at idle, runs erratically still? The engine also lopes and blows out a black stuff out of the tail pipes. Any new ideas that might help me fix this problem. Thanks
Old Feb 11, 2012 | 05:00 PM
critterf1's Avatar
critterf1
Did you check the fuel pressure regulator?
Old Feb 11, 2012 | 06:39 PM
krazymike's Avatar
krazymike
bronco II
I forgot to mention that we replaced the preasure regulater twice. Thanks thow.
Old Feb 11, 2012 | 09:13 PM
L&D's Broncos's Avatar
L&D's Broncos
Die Hard Ford Fan
Running Bad
There are only three things that come to mind right off that I would look at:
1) Have you checked how much vacum it's pulling while trying to idle?
2) Injectors themselves? I have seen it, a lOOOng time ago.
3) Actual ECM? Has this vehicle ever been in a flood or anything?
Not to sound all ending but some things do get overlooked, and you sound as though you have changed everything else. Find an ECM in a salvage yard and try it instead of money on new. Maybe even a set of injectors used. Some scopes can see spray patterns and mapping which may point to culprit. If I had not thrown out wiring and ECM when I converted to V-8 on wifes 89' I would send it to you. HTH
Old Feb 11, 2012 | 10:26 PM
mrshorty's Avatar
mrshorty
It's sometimes hard to tell without being there, but black stuff out the tailpipe seems to be associated with it running rich.
With all that you've replaced, have you actually put a fuel pressure gauge on it to see what the fuel pressure is?
If you pull codes, do you get a rich code, lean code, or pass code?
calansvc
3.8 & 4.2L V6
May 11, 2019 02:08 AM
justroll
Apr 28, 2019 06:33 PM
keepthecoffeeon
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Mar 24, 2018 01:09 PM
Kart18
437
Mar 14, 2018 05:20 PM
