I just broke my rear slip yoke in my bronco after jumping it, the shaft bottomed out and the yoke took the abuse along with the u-joint(differential yoke is fine). My bronc has a semi float Dana 60 rear and the shaft slip yoke is the exact same as the front shaft slip yoke on my 79 f250, hd 44. 16 spline, 354 u-joint approximantly 3 21/32 inches long(with caps on), cap size around 1 and 3/32 inches. Does anyone know of the least expensive yoke I can buy, basically stock 79 250 front? Thanks
