New Guy ford stuff on Oshkosh Chassis need help
#31
#32
You can tweak it a little as long as all of the
positions still work.
Mark the position of the switch in relation
to the steering column. Loosen the hold down
bolts.
Pull the ignition switch a little bit up towards
the steering wheel. That should make
the Start position engage more. Tighten
the nuts.
Verify the Accessory position still works.
Also verify the push on wire at the S
terminal of the starter solenoid is making
good contact. That's the wire that gets
12 volts when you turn the key to Start
and energizes the Solenoid.
bolts.
the nuts.
#34
That's why I was wondering if he pulled that locking pin but
he must have because he said sometimes the engine cranks and
starts.
https://www.ford-trucks.com/forums/1...l#post11413007
If you have a tilt steering column, try moving it to a different position. When
they get wear in the tilt mechanism it can cause problems with the ignition
switch.
#35
He mentioned in post 12 that he replaced the ignition switch?
starts.
switch.
starts.
switch.
I will make a slight adjustment on the switch upwards too
Thank you
