Winch Bumper?
on
I used 3/16 plate and it holds a 12,000 lb Warn[/quote]
Wait till your 12000 comes through that front bumper when a big dodge is real stuck. I used1/4 on mine and broke the drum supports out of my 1988 model warn 12000 cause the twisting action from the rotation. I asked warn to warranty the parts and they asked me a bunch of questions then said "We recommend 5/16 thick mounting flanges on those big commercial grade winches and atleast 6 bolts to mount them, preferably 8 though." I welded some more flat bar across the top to get some more bolts in mine after the repair.
Yeah I do have a write up. Heres a link. I made out of cardboard first to get an idea of shape and style I wanted..
https://www.ford-trucks.com/forums/9...per-build.html
O and if you wanna check out the thread where I make recovery points to aid in a roll over situation using both winches
https://www.ford-trucks.com/forums/9...-recovery.html
can one of you guys tell me what kind of dims are needed for the winch location? I'm gonna build a bumper, but it will be a while before I actually buy the winch and don't want to redo it. Specifically, if you consider the winch to be a block, what h, w and d do I need to leave clear. I'm not too worried about bolt hole locations, unless they are the same on all winches.
Figure out what winch you would like to run. Then look at their specs. For example.
Warn Industries - Jeep, Truck & SUV Winches: VR12000
NBC-Steve
20
05-19-2014 05:19 PM
