Winch Bumper?
Old Feb 12, 2012 | 03:52 PM
impalaslayer's Avatar
impalaslayer
heres another of the warn winch bumper
Old Feb 12, 2012 | 05:31 PM
73 ford guy's Avatar
73 ford guy
Heres the front winch bumper I made..
I used 3/16 plate and it holds a 12,000 lb Warn
Old Feb 12, 2012 | 05:48 PM
Normmus's Avatar
Normmus
That looks fantastic.
Old Feb 12, 2012 | 07:04 PM
F-250 WARHORSE's Avatar
F-250 WARHORSE
I used 3/16 plate and it holds a 12,000 lb Warn[/quote]
Wait till your 12000 comes through that front bumper when a big dodge is real stuck. I used1/4 on mine and broke the drum supports out of my 1988 model warn 12000 cause the twisting action from the rotation. I asked warn to warranty the parts and they asked me a bunch of questions then said "We recommend 5/16 thick mounting flanges on those big commercial grade winches and atleast 6 bolts to mount them, preferably 8 though." I welded some more flat bar across the top to get some more bolts in mine after the repair.
Old Feb 12, 2012 | 07:49 PM
pocket booger's Avatar
pocket booger
Great job on that bumper, is there a write up on it?
Old Feb 12, 2012 | 08:45 PM
73 ford guy
Just so you know the winch is mounted on a 5x5x3/8 thick angle that replacedthe front crossmember. It aint going nowhere!
Old Feb 12, 2012 | 08:48 PM
73 ford guy
Yeah I do have a write up. Heres a link. I made out of cardboard first to get an idea of shape and style I wanted..
https://www.ford-trucks.com/forums/9...per-build.html
O and if you wanna check out the thread where I make recovery points to aid in a roll over situation using both winches
https://www.ford-trucks.com/forums/9...-recovery.html
Old Feb 12, 2012 | 11:34 PM
CXA152's Avatar
CXA152
73 ford guy, Great work. Fits the lines of the truck well, looks strong and doesn't stand out like it shouldn't belong on the truck. Thanks for the inspiration.
Old Feb 13, 2012 | 06:35 PM
brian1080's Avatar
brian1080
can one of you guys tell me what kind of dims are needed for the winch location? I'm gonna build a bumper, but it will be a while before I actually buy the winch and don't want to redo it. Specifically, if you consider the winch to be a block, what h, w and d do I need to leave clear. I'm not too worried about bolt hole locations, unless they are the same on all winches.
Old Feb 13, 2012 | 11:30 PM
CXA152's Avatar
CXA152
Figure out what winch you would like to run. Then look at their specs. For example.
Warn Industries - Jeep, Truck & SUV Winches: VR12000
Old Feb 13, 2012 | 11:58 PM
brian1080's Avatar
brian1080
cool, thanks
NBC-Steve
20
May 19, 2014 05:19 PM
BIG-DADDY-F350
Oct 10, 2012 01:25 PM
vinmanin
Offroad & 4x4
Apr 19, 2010 09:42 PM
theguy_88
Feb 12, 2006 08:51 AM
shooter666
Aftermarket Products
Jan 9, 2004 10:45 PM
