Typical turbo delay?
Old Feb 10, 2012 | 06:52 PM
John Irwin's Avatar
John Irwin
32 psi is pushing it with out head studs. Mine used to hit 31-32 before I got it reflashed, now it only does about 28. I'm sure the updated strategy lowers it, I didn't do anything else. At 32 pounds, you are in danger of lifting the heads off the block and pushing a gasket out due to the weak headbolt design.
Old Feb 10, 2012 | 06:54 PM
zhilton's Avatar
zhilton
Originally Posted by pmoney1983
What do u mean its on the high side of a " non studded" truck? Also the turbo only hit 32 psi a few times with the trailer hitched up. Thats what it maxed out at. It would usually stay between 20 to 28 psi depending on the highway i would be on
When these engines were built, Navistar used Torque-to-yeild bolts (TTY) instead of studs. Meaning they will stretch after a certain point....head studs like ARP won't. If the engine hyrdolocks (excessive fuel or coolant) or too much boost (above 30psi) there is a good chance it will lift the heads thanks to those TTY bolts. Those that were lucky to have their truck lift the heads while still under warranty usually had studs installed when the repairs were made...they had to pay for the studs separately, but several dealerships would install them while they had the heads off. I wasn't one of those lucky ones...so I'm still running TTY until I get around to that project.
Short burst of 32psi is alright...but if it was doing it allot I'd be concerned. Mine has peaked 31-32 pulling the 5th wheel up a interstate pass....and had I left the cruise to it's on devices. When your building boost like that there's also a good chance your EGT are starting to get high (above 1200F)...again, short burst are okay; long periods are bad. When I'm running light, without one of the trailers I can hit 28-29 (according to the EV2) if I do a wide-open blast down the on ramp...got to exercise those turbo vanes routinely too keep 'em from sticking
Old Feb 10, 2012 | 07:59 PM
69cj's Avatar
69cj
In my op. if your pushing over 28 psi on stock bolts your asking for trouble. A stock engine shouldn't go over that unless something is wrong.
RKCORPS25
Oct 22, 2013 09:31 PM
danocross
Jul 20, 2012 09:06 AM
caleb90
20
Jan 30, 2009 09:35 AM
Dustball8504
Sep 27, 2008 07:12 AM
silverstroker
Jul 28, 2006 06:51 AM
