CLUNK IN FRONT END
Old Feb 9, 2012 | 06:42 PM
wulfman's Avatar
wulfman
CLUNK IN FRONT END
Okay got a clunk coming from the front end . Had tires balanced twice by diff people after christmas and was told ball joints were good . Now truck has 157000 on it and original joints, just replaced sway bar bushings and end link bushings they were shot. Just got some bad **** rims and tire guy said ball joint were tight . I have been under truck looking everything looks good, any suggestions .
Old Feb 9, 2012 | 06:58 PM
BLADE35's Avatar
BLADE35
HEY Dave havent Heard from ya in a few you must be Busy Feast or Famine Right
I would have thought that the tire guy would have found it
I used to get a clump everytime it would rain it was under warrenty so let the dealer have it they found a loose bolt on a stabilizer linkage I beleive
Thats great milage on them BJ
I cant hardly check them with the Tire on my tires are to big to have to overcome the tire weight
I know a good suspension guy can tweek it just right with a bar to check them with the tire On
Old Feb 9, 2012 | 07:02 PM
2006powerstroke90's Avatar
2006powerstroke90
Check your U-Joints in your front axle.
Old Feb 9, 2012 | 07:07 PM
wulfman's Avatar
wulfman
Hey Benny yea been busy and also been cutting up my jeep grand cherokee going to build a rock crawler so been on pirate 4x4 forum and jeep forum learning how to build and mod. My buddy thinks its the leaf spring bushings making the noise. guess i am going to have to dig a little deeper.
Old Feb 9, 2012 | 07:11 PM
wulfman's Avatar
wulfman
Tyler i looked at them last time i was under there and they looked dry and normal. And had it locked in pulling my dump trailer out of someones back yard and no noise then , seems like its just on the road running.
Old Feb 9, 2012 | 07:22 PM
zhilton's Avatar
zhilton
Does it clunk often? I know some have reported a clunk that turned out to be the slip joint in the rear drive shaft.
Thinking out loud.....
Old Feb 9, 2012 | 07:31 PM
wulfman's Avatar
wulfman
Zhilton just sometimes when i hit a bump or tap the brakes. The slip joint was replaced at like 30000 under warenty , don't know but will check it.
Old Feb 9, 2012 | 08:25 PM
steelhead2's Avatar
steelhead2
Mine clunks when i hit potholes or sharp edged bumps. Ball joints are tight. Almost sounds like a wore out shock bushing, but theyre tight to. Hope you find it on yours, itll probably point me to my issue.
Old Feb 9, 2012 | 08:41 PM
Mich6.0's Avatar
Mich6.0
Have you changed the shocks with aftermarket units? If so check the metal gromets the bolts go through and see if there is any play , my aftermarket shocks required different size bolts stock bolts were to small. You said the roll bar bushings were replaced ,with stock unit or aftermarket , the kit I bought had the same problem with bolt size.
Old Feb 10, 2012 | 12:12 AM
SoCalSuperDuty03's Avatar
SoCalSuperDuty03
Might check the leaf spring bushings. I have done literally dozens of them over the years on '99-'04 trucks, on both factory and aftermarket springs.
The bushings can look deceivingly good, and still be junk, look them over good.
Old Feb 10, 2012 | 05:34 AM
wulfman's Avatar
wulfman
Thanks for all the suggestions guys , will check it out a little more . If and when i find it will check back.
Old Feb 10, 2012 | 06:48 AM
critterf1's Avatar
critterf1
Look real close at the caliper mounts.
Old Mar 26, 2012 | 04:19 PM
Kwise01's Avatar
Kwise01
Wulfman, did you ever find the source of this noise?
My excursion has developed a similar noise coming from front passenger side...only when going over bumps.
Old Mar 27, 2012 | 12:27 PM
built tough's Avatar
built tough
my dad has a 04 and it had the clunking noise we tightened up the sway bar i beleive and that eliminated it
Old Mar 28, 2012 | 01:33 PM
Texas Bob's Avatar
Texas Bob
What's one man's clunk is another man's clink. That said, i had a clunk/clink in the front of the truck that seemed to evidence itself when we went over potholes or other changes in the surface of the road. It turned out to be the front stabilizer links and they were replaced under my Ford extended warranty with Ford parts. If I had done it myself, I would have upgraded to MOOG heavy duty greaseable links.
Gavin6.0
Apr 3, 2019 05:58 AM
Metz22
13
Mar 1, 2016 08:09 AM
theclintonsx4
Dec 21, 2011 12:05 PM
K9BELLA
Jul 11, 2010 01:21 PM
mudbug04
Aug 5, 2009 08:26 AM
