Dash light frustration '66 stylside.
Old Feb 9, 2012 | 06:20 PM
chromejunkie's Avatar
chromejunkie
After the rigged elec. fuel pump wire kept coming loose and stalling me, I decided to clean up some of the rats nest of wires going to the fuse block. Now...everything works great except all the dash lights stay on when the headlight switch is pulled and no turn signals. There is a little flickering when rotating and after reading other posts would indicate a possibly bad switch. All of the bulbs inside and out are good and I have a wiring diagram and went through the instruments. Thoughts?
Old Feb 12, 2012 | 12:50 AM
mexiamericano's Avatar
mexiamericano
I would have to guess the switch as well. I had previous issues with mine, the **** would just spin. Just so happened that the contact wheel spring broke off. So after replacing it problems were solved,good as new lol
Old Feb 12, 2012 | 06:30 PM
chromejunkie
Thanks..I guess at least I would have a new switch.
Old Feb 13, 2012 | 02:48 PM
camperspecial65's Avatar
camperspecial65
ive got a h/light switch if you are stil in need..email for more info or post your email and I will reply
- cs65
dharte
Nov 22, 2014 11:10 PM
baumst
Jul 10, 2011 10:00 PM
johninraleigh
Dec 22, 2007 11:05 AM
davE350
General Diesel Discussion
May 12, 2007 02:55 AM
desperado_18_2000
Apr 3, 2003 11:38 PM
