I have all of the other things working, checked the fuses under that dash, all OK. Could it be my light switch? How do I check that to rule it out as the culprit?
I do have brakes & turn signals.
I bet it is the light switch. Check the incoming power to the switch and the outgoing, with a volt meter, with the switch on. If they are different replace the switch.
Yes, a salvage yard should be fine. A friends did the same about a month ago and we got one from the salvage yard and used is original ****. Worked like a champ.
