Pulling the idm
Old Feb 9, 2012 | 06:01 AM
Diesel cat's Avatar
Diesel cat
Pulling the idm
Hey guys just a quick question for the brain trust. I'm pulling my Idm for mod and just wondering should I disconnect the batteries before I disconnect it just to be safe.
Old Feb 9, 2012 | 06:56 AM
BlueMule's Avatar
BlueMule
Nope, just make sure the key is off.
Old Feb 9, 2012 | 07:19 AM
Ken_C's Avatar
Ken_C
It is wise to disconnect the batteries any time you do electrical work on any vehicle. however, I have heard that if you connect a 9volt battery and a blocking diode to the cigarette lighter socket before you disconnect them, you might not lose your presets on the radio. haven't tried that trick yet. but next time i need to disconnect the batteries...
the memory and clock in most radios only needs 3.3 or 5 volts to function. theres a nice regulator circuit that takes 12v from the constant power and regulates it down to the needed voltage. so 9volts would also work.
Old Feb 9, 2012 | 07:27 AM
Diesel cat's Avatar
Diesel cat
Thanks for all the info. I figure better play it safe and disconnect the batteries.
Old Feb 9, 2012 | 07:28 AM
fordpride's Avatar
fordpride
I've never dissconnected them to pull the IDM
Old Feb 9, 2012 | 09:29 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Exclamation
Neither I. Just keep the keys in your pocket.
2012 F250 6.2
May 6, 2018 01:07 PM
SD Rick
Nov 11, 2013 12:22 PM
SnuffthePunkz
16
Nov 19, 2010 12:07 PM
bkks744
Feb 8, 2008 09:24 AM
afinepoint
Sep 14, 2004 04:20 PM
