The back pillar trim pulls straight off. It might be quite tight. There should be a screw behind there.
There is a screw behind the door handle. You pull the trim piece off from around the handle to access it.
If you have power windows and locks you pull up on the piece that they are in to remove it. Then unplug the connectors.
After that you lift the door panel up to remove it.
