Escort Radar Detector Install
Old Feb 8, 2012 | 05:18 PM
excoelis's Avatar
excoelis
Not sure where to post this so figured I would put it here, my appologies if it belongs in a different thread
Installed a Escort Radar and quite happy how it looks, has anyone else used the mounts from Blendmount or something different? It is installed in 2010 F-150 SCrew FX4.
Detector is mounted using a mount from www.blendmount.com. It attaches to the mirror stem very secure and there is no movement even over rough roads. As you can see it keeps the radar up high and to be honest it isn't even visible from the front. As far as removing it it is simple, you squeeze 2 tabs on the mount together and the radar slides out.
It is wired in using a Mirror tap, you simply push 2 wires into the 12v and ground wires of the mirror and you have power to the radar everytime you turn your key on. You need a Auto Dimming mirror in order to do this.
This is all available from www.blendmount.com and I can tell you guys the customer service there is exceptional.
Old Feb 8, 2012 | 05:26 PM
tseekins's Avatar
tseekins
Veteran: Coast Guard
Tell us a little more about your F-150 and how you mounted, wired,etc.
Old Feb 8, 2012 | 05:30 PM
BIGKEN's Avatar
BIGKEN
Gee...I haven't used a radar detector in years. I guess driving reasonable spped works!!! The mount looks good...easily removeable when you park.
Nice job.
Old Feb 8, 2012 | 06:48 PM
cdmm151's Avatar
cdmm151
I still use the visor mount and run the wires in headliner and down A pillar.
Old Feb 8, 2012 | 09:32 PM
joendoodle's Avatar
joendoodle
I mount mine just below the mirror, run the wires in headliner and inside the A pillar, then inside the dash (no "unsightly" plug to contend with)
Old Feb 9, 2012 | 08:02 AM
cdmm151's Avatar
cdmm151
Just curious what is the antenna thing in the picture?
Old Feb 9, 2012 | 05:54 PM
excoelis's Avatar
excoelis
Updated with explanations;
The antenna is for my remote starter.
Old Feb 20, 2012 | 02:33 PM
extremejv's Avatar
extremejv
Did the same...
I did a similar install, works and looks great!
https://www.ford-trucks.com/forums/1...ew-mirror.html
Old Feb 20, 2012 | 05:57 PM
LxMan1's Avatar
LxMan1
i mount mine to the glass out of sight in the tint strip and bought pins for $1 at Radioshack and wired mine myself. Turns of with the key in run only and is invisible from outside.
I've seen too many mirrors fall of of the glass to add any more weight to mine.
Old Nov 29, 2014 | 10:32 PM
TommyRox's Avatar
TommyRox
Just received mine and wondered if you remember the 12V and GND pins - thanks in advance!
Old Nov 29, 2014 | 10:50 PM
excoelis's Avatar
excoelis
Sorry I don't and I sold the truck so I cant look, I do remember just touching the wires on each one until there was power and then pushing them in.
Old Nov 30, 2014 | 04:18 PM
xr7gt390's Avatar
xr7gt390
I mount mine on the glass above the mirror using the suction cups. I don't want anything hanging from my mirror.
Old Dec 17, 2014 | 03:32 PM
extremejv's Avatar
extremejv
2010 Lariat
For my 2010 Lariat the rearview mirror has a seven pin connector. Connect the yellow pin to pin 1 and the black pin to pin 3. The detector (Escort 8500 Blue) works great and turns on and off with the ignition.
Got the cord from here:
Invisicord Products Home Page
That was a while ago, there maybe other options by now.
LSCRX
Jul 29, 2019 08:39 PM
johnkn
May 8, 2013 10:39 PM
Bonkrr
1997 - 2003 F150
Apr 6, 2012 12:02 PM
