odd vibration situation...
Old Feb 8, 2012 | 02:17 PM
insane_goofball's Avatar
insane_goofball
ok... kind of odd here but i will try to explain as best i can.
under full throttle acceleration. i get a pretty strong vibration.
i flushed 30 quarts of trans fluid through trans. and added 2 bottles of shudder gaurd.
no noticable difference. took it to an ammco trans shop. he suggested it COULD be torque converter. or it could be driveshaft vibration. (i lined up u-joints correctly) it is a 2 pieces driveshaft assembly. i also have an exhaust leak at drivers manifold. i am installing flowtech headers next tuesday and true dual exhuast. along with a FULL msd ignition system with a 6a spark controller.
tires are freshly balanced. new wheel bearings and front rotors.
i feel the vibration in park just revving it up past 3k. i am leaning towards a possible bad harmonic balancer as being the cause... i have gone through 3 tensioners and 2 belts in the past year.
does the balancer seem like a likely cause? has anyone else had this issue? i DO have a crossfire condition currently. part of the reason i am upgrading the ignition.
any help would be appreciated.
Old Feb 8, 2012 | 03:48 PM
gasman6674's Avatar
gasman6674
Has the truck been wrecked? I had a bent PS pully on my 97, drove me nuts until pump started leaking and found the bent pully.
Regards
Old Feb 8, 2012 | 09:57 PM
732t37's Avatar
732t37
You never said which engine you have. That might help.
Becuase you get the vibration in "Park", and, as you said, the truck eats belts, I'd say there's a pretty good chance the balancer or a pulley is no good. It's pretty easy to check visually.
My "DO NOT TRY THIS AT HOME" method is to hold something on the edge of the pulley and see if it vibrates. This is extremely dangerous though.
Old Feb 9, 2012 | 01:33 PM
insane_goofball
guess i did leave out some info there...
302 v8.
new water pump.
new p/s pump and pulley.
new fan clutch.
3rd tensioner (this one is from advance, seems better than autozone or napa)
new idler pulley
i have work to do on the wifey's sport trac today. but if i have time, i will pull serp belt off of mine, and run it to see if i still have vibration. that would eliminate all accessory pulleys and devices. and narrow it to exhaust, harmonic balancer, or *GULP* internal engine issue.
TestPoint
Mar 9, 2015 07:00 AM
ButchWhitehouse
Jul 26, 2002 10:54 PM
jbulson
May 14, 2002 06:35 PM
FIREDUDE26
May 30, 2000 04:21 AM
