VIBRATION PROBLEM
Old May 22, 2000 | 01:35 PM
FIREDUDE26's Avatar
FIREDUDE26
VIBRATION PROBLEM
I have a 68, 240 manual, it has a vibration in the moto, i know it is not in the drive train, i just bought truck and have know idea what was done to it before, i check the crank pulley and it seems fine. if you know or have any ideas on what the problem could be let me know...
thanks rob
Old May 23, 2000 | 11:01 AM
FE427TP's Avatar
FE427TP
VIBRATION PROBLEM
I had a 240 in my truck before I put the 360 in it and it had a vibration around 60mph in the shifter, all I did was change the bellhousing, it still has the same NP 4 speed but now it doesn't have the vibration that I notice
Old May 23, 2000 | 12:44 PM
FIREDUDE26's Avatar
FIREDUDE26
VIBRATION PROBLEM
the vibration is in the MOTOR not the drive line it has the vibration at idle even if i have clutch pushed in i still have vibration, thanks
Old May 23, 2000 | 04:47 PM
dmcadams's Avatar
dmcadams
VIBRATION PROBLEM
My father in law had the same problem in a 69 mustang and he swore it was the motor vibrating too. When working on tranny linkages we noticed that the transmition mount was broke and after changing it the vibration was gone. This might not be your case but it's worth checking in to.
Old May 24, 2000 | 12:43 AM
FIREDUDE26's Avatar
FIREDUDE26
VIBRATION PROBLEM
ok thanks i will do that i also had someone tell me to check the motor mounts, but i think it is something directly connected with the motor..
Old May 29, 2000 | 05:04 PM
FIREDUDE26's Avatar
FIREDUDE26
VIBRATION PROBLEM
i was wondering if it had the wrong pulley on the crank? it has a double pulley, it has no options, why would it have a double pulley????? does anyone know if i take it off and start motor if the vibration went away, would that be the problem??
Old May 30, 2000 | 04:21 AM
jowilker's Avatar
jowilker
VIBRATION PROBLEM
