high amp alt
Old Feb 8, 2012 | 06:56 PM
  #31
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Originally Posted by SCRebel
I have a 89 belt system. So will I need the wiring harness also with the alternator? I have a 89 F150 with a 351w. I would like the 3g 130 amp alt.
Not trying to tread hijack.
FOJ already has....
You will need a charging cable, a fuse & holder, and to jumper the harness as shown in the link in post #12.
The regulator plug is the same, 2G & 3G.
You can get an eyelet to eyelet #2 cable at any autoparts store for $10.
My 460 has the alternator on the bottom, so I don't know what length you need for a serpentine Windsor.
Or you can buy the harness and charge cable kit through the link, or many other places on the internet.
RJM Injection Tech — Alternator Charge Cable Kit
RJM Injection Tech — 3G Alternator Harness
(EDIT) I just want to make sure everyone knows I do not represent RJM.
I have used their products and they work well for me in my application
I am linking images from that site because I know where they are and they show in detail what's needed.
---No affiliation, just a satisfied customer, Bla, Bla bla,---
Old Feb 8, 2012 | 06:57 PM
  #32
88dually's Avatar
88dually
Will running dual 3g's an multiple batt's with an isolator be a problem ?
Old Feb 8, 2012 | 07:02 PM
  #33
SCRebel's Avatar
SCRebel
Originally Posted by ArdWrknTrk
FOJ already has....
Thank you sir. I believe you have answered my question. This will be on of my upgrades in the near future.
Old Feb 8, 2012 | 07:06 PM
  #34
deljac's Avatar
deljac
so i have a 96 f150 with the windsor will a 3g bolt up to mine without any changes other than wiring
Old Feb 8, 2012 | 07:09 PM
  #35
88dually's Avatar
88dually
Yes, PnP. Get the right alt for ur mounting brackets
Old Feb 8, 2012 | 07:10 PM
  #36
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Originally Posted by 88dually
Was the original question of, can it be done, get answered, i may have missed it
Direct fit... No, not quite.
As I showed, the bracket needs to be opened up a little for the larger alternator, and some basic wiring needs to be done.
Removing the fire prone 2G charging plug and replacing it with a fused heavy cable.
Old Feb 8, 2012 | 07:13 PM
  #37
deljac's Avatar
deljac
ok thanks for all the help guys
Old Feb 8, 2012 | 07:15 PM
  #38
88dually's Avatar
88dually
Will there be a problem running 2 3G's with 3 batt's on an isolator ? 2 batt's will be mounted on pass frame.
Old Feb 8, 2012 | 07:16 PM
  #39
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
The 95A 3G will fit the Windsor serpentine bracket without clearancing, but you still need a heavier cable.
The 65A 2G was already overloading the dual 10g harness found in the truck.
You could use one as a welder or to run a winch.
You would need some SERIOUS cable to run both of them together.
And really, why bother?
How much load do you possibly have?
Old Feb 8, 2012 | 07:24 PM
  #40
88dually's Avatar
88dually
How heavy a cable(s) for 2 130a. 1#lt an batt for truck. 1 alt an 2 batt's for compressor, inverter, 1000w work spot lights, possible winch an a few other accessories. Will there be a problem running cables near starter or anything else, or other cables on frame ?
Old Feb 8, 2012 | 07:45 PM
  #41
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
2/0 cable is rated for 283 chassis amps, so it should carry two 130A alternators.
American Wire Gauge table and AWG Electrical Current Load Limits with skin depth frequencies
I am NOT an electrical engineer, my father is...
I don't think you will see any inductive interference with a steady DC current, but again I don't feel I am qualified to make this a factual statement.
Remember you will need enough belt friction to drive these things, and in my experience that is the limiting factor.
Old Feb 8, 2012 | 08:01 PM
  #42
88dually's Avatar
88dually
Each alt is goin to seperate batt's. Then isolator ? Also figuring a way to mount another pulley wheel to the right of alt's next to water pump pulley so belt should contact roughly 180 * of each alt pulley. That should work ?
Old Feb 8, 2012 | 08:08 PM
  #43
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
A horsepower is 746 watts.
The 130A puts out roughly 1800 watts, X2 = 3600 / 746 = about 4.8 Hp.
That's a LOT more for a belt to drive.
Especially if it has to drive other things like a water pump, power steering pump, air conditioning compressor, etc...
Remember ALL this has to be driven by the ONE crank pulley.
There's just not enough surface for the friction.
Old Feb 8, 2012 | 08:15 PM
  #44
88dually's Avatar
88dually
Put extra wheels closer to alt pulleys to get near 270* ?
Old Feb 8, 2012 | 11:02 PM
  #45
FordOwnerJoey's Avatar
FordOwnerJoey
Thats another reason why I wanted more power, is to be able to run power tools if I need too. I doubt I would have any lights on when Im doing it but maybe just the implement lights for cargo/work lights. as long as I can wire up a converter to run tools or something Ill be happy, then off road run my lights
