Lifting
Old Feb 8, 2012 | 09:29 AM
cam_polaris's Avatar
cam_polaris
Lifting
Does anyone know where I can find a body lift kit for my 1996 F-250 7.3L diesel truck? everywhere i look on the internet they have lift for non diesel f250s
Thanks,
Camryn
Old Feb 8, 2012 | 09:38 AM
DIYMechanic's Avatar
DIYMechanic
They should all be the same. The body is the same across both platforms. Be aware though that with a body lift comes a lot of squeaks and rattles...
Old Feb 8, 2012 | 09:48 AM
cam_polaris
im just confused because all the kits said will not fit truck with diesel engine
Old Feb 8, 2012 | 10:08 AM
gengine's Avatar
gengine
You might make a phone call to one or more of these companies. A live person will be able to tell you if they will indeed fit, or why they don't. Then you can post here and let us know!
Old Feb 8, 2012 | 10:13 AM
redman84's Avatar
redman84
Are maybe the mounts in the rad support different for the diesels?
Old Feb 8, 2012 | 10:35 AM
DIYMechanic
Brown Falcon had one on his truck for a while. I am not sure if he purchased it himself or not, but I think he did the install. He might be a good one to ask.
Old Feb 8, 2012 | 11:05 AM
fordpride's Avatar
fordpride
They are showing f250 non diesel and f250/350
Ford Body Lift Kits
Old Feb 8, 2012 | 11:59 AM
DIYMechanic
I see the '97 F250/350 dually but I don't see the issue. Order the one that is listed as 92-96 F100/150/250/350. That one will work. I honestly don't think there is any difference in the frame horns for the diesel core support, but I cannot verify that from first hand experience.
Old Feb 8, 2012 | 02:20 PM
Ford4Life7.3's Avatar
Ford4Life7.3
If you do any heavy towing dont do a body lift...
Old Feb 8, 2012 | 02:37 PM
fordpride's Avatar
fordpride
Fill me in what am I missing?
Old Feb 8, 2012 | 09:29 PM
Mdt1992's Avatar
Mdt1992
probally referring to them overheating with the fan misaligned, at least thats what ive heard
Old Feb 9, 2012 | 06:41 AM
DIYMechanic
Either that or I would think using a fifth wheel or goose neck hitch would be a little problematic with a body lift holding the bed that far above the frame. You would have to come up with a "field engineered" way to make it so the hitch plate or rails were putting the weight on the frame and not on the bed.
Royson12
19
Sep 5, 2010 01:17 PM
F250Diesel4x4
Offroad & 4x4
Mar 14, 2004 10:12 PM
LiftedZJ
May 7, 2003 09:24 PM
NoMo
Jun 4, 2002 06:33 PM
