Sponsored by: Real Truck
Lift Kit Adjusting
Old Feb 7, 2012 | 07:49 PM
Cali Dad's Avatar
Cali Dad
Lift Kit Adjusting
I have a 2001 F250 7.3 and recently had a Pro Comp leveling kit installed. It gave me at least 2 inches of lift up front if not more and I now have to use my rear air bags to adjust the rear height to meet the front. Are the Pro Comp kits adjustable? I'd like to bring the nose down a little and get some pressure out of the air bags, it makes for a stiff ride on a daily basis. The part number on the installed springs is 22210. Thanks in advance!
Old Feb 7, 2012 | 08:49 PM
Joe Bloomingdale's Avatar
Joe Bloomingdale
I'm not sure how you would drop the front down but maybe you can raise the rear, the rear F-250 block can be replaced with a block from a F-350 which will give you..If I remember correctly another inch and a half of height.
Old Feb 7, 2012 | 09:24 PM
Cali Dad's Avatar
Cali Dad
Lift Kit Adjusting
Thanks, I'll look into doing that. It ended up with more lift than I expected but the real killer is the stiffness of the ride with the airbags needing inflated. I'll check out the F350 blocks.
DHamSTER
Aug 20, 2013 03:09 PM
remhaust
6.7L Power Stroke Diesel
34
Oct 2, 2012 07:55 AM
beer-30
Jun 16, 2009 10:42 PM
lariat79sc
Feb 16, 2008 06:48 AM
Lovemyfords
Offroad & 4x4
Aug 4, 2006 07:29 AM
