Injector Cleaners ??????
Old Feb 7, 2012 | 07:53 PM
FICMrepair.com's Avatar
FICMrepair.com
Former Vendor
Like other posters have said, check your FICM voltages.
I love my Edge Insight CTS over my ScanGauge, but either will let you check FICM voltages and read codes, too. Of course, so will a digital volt meter...
Directions for reading the voltages are on our web site in the FAQ section.
Ed
Ed@ficmrepair.com
Old Feb 8, 2012 | 06:37 AM
npccpartsman's Avatar
npccpartsman
Originally Posted by Teds
one code from the sct, p0237 (turbo sensor something)
MAP sensor code circuit code, which can be a wire or the MAP sensor but most likely sensor. This can cause you performance headaches too.
Old Feb 8, 2012 | 07:58 AM
tonefordays's Avatar
tonefordays
One important thing to remember when checking your FICM, is to check it on a Cold Start. Once things have warmed up, often times the voltages will read normal. Before I got my SGII, I used a voltmeter on the FICM screws, voltages looked good, however this was right after I drove home from work, soon after, I received my SGII and noticed that the voltages were dropping to 30v, but ONLY during a cold start. Once the engine/fluids were nice and warm, things were good.
Old Feb 8, 2012 | 01:49 PM
Teds's Avatar
Teds
npcc if it is the map sensor will it clear up as the truck gets warm??
we will be hooking the computer up here at work to see if any other codes and to check the ficm, what should it be??
Old Feb 8, 2012 | 01:57 PM
Teds's Avatar
Teds
nevermind i see it on ficmrepair website
Old Feb 8, 2012 | 02:30 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
but i would rather spend a little more for the edge insight cts,
The CTS does somethings the SCII doesn't, and vice versa. For diagnostics, the SCII wins- you can program in more PIDS (EPB, IPR%, ICP, etc) that the CTS can't view but are very important to troubleshooting certain conditions. The CTS will read codes and can pull a few details out of the truck that the SCII can't.
I have the CTS and it's great for day-today things that you should watch all the time (ect/eot split, EGT, tft, V and FICM V), but I'm probably going to order an SCII here pretty soon to start checking on other things that the Edge just can't.
Old Feb 8, 2012 | 02:52 PM
FICMrepair.com
Former Vendor
That's precisely why I hung onto my SGII after the Insight CTS showed up, actually. It's an unbelievable tool for the money.
Ed
Ed@ficmrepair.com
Old Feb 8, 2012 | 03:05 PM
Teds's Avatar
Teds
wow thats interesting info to know....thnx
Old Feb 8, 2012 | 04:15 PM
Teds's Avatar
Teds
just ordered the scan guage II, should be here fri or sat
Old Feb 9, 2012 | 09:11 AM
Teds's Avatar
Teds
something just crossed my mind, the missing problem i am having at cold starts was doing it before i got the head work done, got it back and ran perfect every cold start for almost 1000 miles then started it again, would that make sense for it to be the ficm ??
Old Feb 10, 2012 | 01:44 PM
FICMrepair.com
Former Vendor
Assuming nothing else changed, no. The best bet remains to pull the codes and see what the SGII tells you rather than just throwing money at parts.
Keep us posted!
Ed
Ed@ficmrepair.com
Old Feb 10, 2012 | 02:22 PM
Teds's Avatar
Teds
i was just getting ready to post updates..
sgII not in yet...
i am know getting constant miss even after warmed up, so i took it to mechanic last night to have him check ficm, he went to drive it and said wow this things missing bad, w truck warm, it was as 48.5 dropped to 47.5 cranking.he ran codes came up w P0237, P0272, P0403,P0480, P0528....
did injector diag, #4 was changing as low as -48 while the others remained at 0
he had me leave it so he could check it this am when cold. went over this am he hooked it up, ficm - lowest it was was47.5 cranking and stayed at abt 48.. so looks like ficm may b okay..
injector diag showed #4 #6 #7 all dropping to negative numbers jumping all over the place, he suggested we use the bg clean system, one qt treats fuel, 2nd treatment goes directly in the oil, stuff was like alcohol, let set idle for 1.5 hrs, drained and purged system, new oil filter and royal purple 15w40 and 1 qt of bg DOC, diesel oil conditioner......went and drove truck was still missing a little..
he had reset the codes earlier but the codes came back showing #4 injector, told me to drive it for awhile to work in the fuel treatment, upon driving it will clear up and run great then start the miss agn under acceleration, then clear up agn....
thats where i am to this point...
here is video from earlier.....
http://s139.photobucket.com/albums/q282/MYPICS75/?action=view¤t=photobucket-3559-1328900886758.mp4
http://s139.photobucket.com/albums/q282/MYPICS75/?action=view¤t=photobucket-3905-1328902313275.mp4
Old Feb 10, 2012 | 02:42 PM
  #28
Teds's Avatar
Teds
it hard to hear the missing from video but if you listen close u can hear it cutting out
gauges showed egt at 1000 and boost went just over 32
Old Feb 10, 2012 | 04:26 PM
  #29
Teds's Avatar
Teds
any thoughts or suggestions??
Old Feb 10, 2012 | 11:38 PM
  #30
Teds's Avatar
Teds
Left work tonite and same issues cutting out missing real bad....must be those 3 injectors any ideas or is it time for injectors???????????????
