95 cab mounts
Old Feb 7, 2012 | 11:33 AM
fordka's Avatar
fordka
95 cab mounts
when iclimbed under the cab i can only see the front 2 cab mount bolts. is there any more. im not going to unbolt im going to torch them off. is there any more and does anything have to be takin off or should i just see them if there are any more. thanks
Old Feb 7, 2012 | 01:24 PM
Motsch788's Avatar
Motsch788
Your rear cab mount bolts will be right behind the seat... Pull up the back of the carpet and you will find the head of the bolts. You will then need to crawl under and find the nuts at the end of those bolts. Be careful... Im sure you are aware that rubber burns when its near a torch.
What 'cha doin pulling the mounts anyways?
Old Feb 7, 2012 | 02:00 PM
fordka's Avatar
fordka
Well no i sold the cab and i should have had it off by now and he told me just to cut the bolts.
Old Feb 7, 2012 | 02:56 PM
Diesel_Brad's Avatar
Diesel_Brad
It is ALOT easier to just unbolt the mounts
Old Feb 7, 2012 | 03:03 PM
fordka's Avatar
fordka
not when you cant tell the bolts have threads any more because of the rust
Old Feb 7, 2012 | 03:20 PM
Diesel_Brad
I have NEVER had to torch a cab mount bolt. They always come right out.
Taking the mount apart, well that is a different story
rizob01
Aug 5, 2018 08:28 PM
GMbusa
18
Mar 4, 2016 12:43 PM
ID1982F150I6
13
May 12, 2014 10:36 PM
JWest
16
Jul 13, 2007 08:58 PM
79 posi
Apr 4, 2005 08:01 PM
