Stalling 78 351m
Old Apr 22, 2003 | 07:40 PM
mrmrschris's Avatar
mrmrschris
Angry Stalling 78 351m
I have a '78 F-150 4x4, 351m, Manual, which will start and run to idling temp., or shortly longer, then just cut-off, as if I turn key off.
It used to not start back up til sitting for long while. I replaced: coil, plugs, plug wires, battery, voltage regulator, ignition module,
starter solenoid, dist. cap, rotor button, all with new parts. Now when it cuts off, it will start back up and cut right back off. Please
H-E-L-P, I'm going nuts!!!!, It's driving me to drink!!!
Old Apr 22, 2003 | 10:56 PM
bigblue250's Avatar
bigblue250
Stalling 78 351m
I had the same problem in my 76' did you replace the module in the distributor that plugs in to the harness? I replaced the one in my truck in about 10min for I think$12 just dont loose the little clips that hold the distributor guts in. Hope this solves the problem.
tubbith
20
May 29, 2012 01:39 PM
shady81
18
Oct 5, 2010 10:51 PM
wareaglehey
Jul 24, 2009 07:09 PM
red rock 78
Mar 11, 2009 07:42 AM
78ford351m
Apr 14, 2006 12:12 PM
