Carb trouble
Old Mar 8, 2009 | 10:29 PM
red rock 78's Avatar
red rock 78
Carb trouble
yesterday I had driven my 78 f150 a good distance from home since I put my new gas tank on. There was a incident were I had to speed up when I did as I slowed down my truck started to cut off it finally did.I got it cranked I was low on gas so I filled it up and got back on the road. I made about 2 miles it cut off again. I sat there a few minutes and kept turning it over it finally cranked then I drove it home. I noticed when pressing the gas there was a slight pop from the carb. Could it be trash in the line ,fuel pump ,inline fuel filter ,or the float. I think it's a 2150 2 bbl. motorcraft (autolite) on a 351m.
Old Mar 9, 2009 | 12:28 AM
Ranger76's Avatar
Ranger76
Was the pop heard while the engine was running? If so, it could be backfiring out through the carb. I would check your fuel filter, and if you got some extra fuel line attach it to the output side of your fuel pump(the side that goes to the carb) and run it into a bucket, crank over the motor until the fuel starts flowing into the bucket and check and see how well it flows, it is a bearly trickling out you might have a blockage in the line. If it pours out a nice slow, but steady rate, you probably don't have a problem there. You might just need to rebuild the carb, but that "poping" you describe needs to be diagnosted first, with could mean timing is out. Hope this helps.
Old Mar 9, 2009 | 01:01 AM
classicfordman's Avatar
classicfordman
yeah i would check the timing first, thats usualy the first thing that will gause it
Old Mar 9, 2009 | 10:34 AM
fulltime_79's Avatar
fulltime_79
also, look in that bucket of fuel for any water after it sets a little
Old Mar 10, 2009 | 10:10 PM
red rock 78
thanks to all who gave advice I checked the timing and it was off I reset it. I think that solved the problem. I'm going to drive it around tomm. if it did'nt solve it I will check fuel line.
Old Mar 11, 2009 | 07:02 AM
scottlane's Avatar
scottlane
I have experienced the same thing and it was trash in the fuel filter. Don't know where it came from but the clear glass filter came in handy that time.
Old Mar 11, 2009 | 07:42 AM
Ranger76's Avatar
Ranger76
I bought one of those glass filters once, I put it on my LTD and it leaked, the glass wasn't sealed on there correctly, it was a spectre brand, won't buy those anymore.
DoubleAr0n
28
Jun 2, 2014 10:22 AM
tubbith
20
May 29, 2012 01:39 PM
shapechanger101
Bronco II
Oct 3, 2011 08:52 AM
bmccartney
Mar 21, 2009 08:14 PM
dkrool
1978 - 1996 Big Bronco
Dec 16, 2002 07:03 AM
